stock 2003 (vdc) 18" tire up grade?
Old Jan 3, 2008 | 07:43 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by yuri
Alberto you saying in fact i can go 265's in the rear with my 03 stock rims???? despite what all these z gurus are telling me?
It will pudge some, depends on if you like the look. I personally do, it looks aggressive. If you have any doubts though, go with the 255 size, although from what I recall when searching that size was hard to find in a good tire. Ive run 265 on 8.5" track wheels, my GF has run it on 8" wide and my friend has run em on 8" wide touring 18's, it look sgood and meaty.
Old Jan 3, 2008 | 03:01 PM
yuri's Avatar
yuri
I like meaty too I have a 03' touring and according to these guys nothing meatier than 245 will fit? but if your certain I'll give it a shot
Old Jan 3, 2008 | 03:16 PM
InZomniac's Avatar
InZomniac
I had 275 on my rear 03 touring wheels with 0 problems or issues.
Old Jan 8, 2008 | 07:10 PM
yuri's Avatar
yuri
A lot of people are saying that it isnt possible because you cant fit 275's on 18X8 which are the wheels that come with the cars we have (03 touring)...I wanted to originally put 275's in the rear and 255's in the front (a difference of 20mm) . that would maintain the original stagger of 245 rear and 225 front (a difference of 20mm)...but they say it couldnt be done???? what size did you have in the front in how did the car feel????? did the car feel heavier and less agel then before???
Old Jan 9, 2008 | 04:43 AM
lowrider's Avatar
lowrider
Well I'm happy for you. You do realize that you have no warranty either from Nissan or the tire manufacturer because you are running a not recommended application. If something happens no one will except liability. You may have an action against the tire shop that allowed the installation.
Happy driving and keep those bulging sidewalls clean and away from curbs.
Lou
Old Jan 9, 2008 | 04:58 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
so if you did this with a 40 side wall would it cause your vdc to go retarded?
Old Jan 16, 2008 | 05:23 PM
cultcar's Avatar
cultcar
A reputable tire shop like tire rack, discount tire, or ntb will probably turn you down because you are differing from the manufacturer recommendation. Check out the attached article below from 2003:
350Z Rubber Meets the Road
These cars come with Bridgestone Potenza RE040 tires. The tires have a rating of "140" treadwear, "A" temperature, and "A" traction. "A" ratings are good, although you can now find performance tires with "AA" traction ratings. The treadwear rating of 140 is extremely low - one of the lowest in the performance tire arena. Because of this you can expect the tire to last only 10 to 15 thousand miles, depending on your driving style! When they are ready to be replaced, do NOT buy this OEM product.
Much better tires can be had for a lot less money. As an example, in the 225X18 and 245X18 sizes on the Performance, Track, and Touring 6MT models, a set of RE040s run $1038 at the Tire Rack, whereas a set of
S-03s run only $760. The S-03 is Bridgestone's top-of-the-line tire and it has better performance and wear characteristics than their RE040.
Now, I bet you want to get new tires based on "plus" sizing. Don't do it! For those with the 17" wheels you are not able to do this without exceeding the tire manufacturer's recommendations on minimum wheel width. The 7 1/2" wide front wheel can't take a tire width beyond the standard 225/50. Those with 18" wheels all around can't plus size their tires either, because their rear 8" wheel can't go beyond the current 245/45. Let's face it, these cars are already tweaked! The only 350Z model that can properly go a plus size and (barely) stay within manufacturer's recommendations are the Track models. Their 8" front wheels can accommodate a 235/40 and their rear 8 1/2" wheels can take a 255/40, all for less than a $1000. So, for most of us 350Z owners, plus sizing means new wheels, too!!!
350Z MODEL WHEELS (F-R) TIRES (F-R) PLUS SIZE TIRES
Base, Enthusiast, 17x7.5 – 17x8 225/45 – 245/45 Front is maxed;
Touring AT need wider wheels
Performance,
Touring 6MT 18x8 – 18x8 225/45 – 245/45 Rear is maxed;
need wider wheels
Track 18x8 – 18x8.5 225/45 – 245/45 235/40 – 255/40
350Z_Al
Oct 29, 2020 07:44 PM
ablaine
Nov 29, 2016 10:13 AM
