Quick question, please read
Old Dec 30, 2007 | 09:48 PM
zyou8er's Avatar
zyou8er
Default Quick question, please read
Took the front wheel off today, and my brother noticed that there is a 12mm bolt on the front rotors, and it has like a spacer or something. Its bolted on the rotor, can this be removed? or what is it for, to push the rotor out when doing a brake job? Thanks.
Old Dec 30, 2007 | 09:58 PM
415mm's Avatar
415mm
Professional
that bolt is there so you don't switch the front oem wheels with the rears. it has no bearing on you're brakes or removing you're rotors. it is easily removable and will do no harm in taking it off.
Old Dec 30, 2007 | 10:18 PM
zyou8er's Avatar
zyou8er
Default Thank you
Me an my brother just installed my wheels on his car
Old Dec 31, 2007 | 12:44 AM
terrasmak's Avatar
Actually if the rotor sticks on the hub, just thread a bolt into it to remove the rotor. Same as plenty of other cars.
Old Dec 31, 2007 | 02:14 PM
Escobar's Avatar
Escobar
Q. I can't get my new rims to fit on the front. There's a little bolt there! What can I do??
A. That little bolt is there so your tire guys don't put your stock rear rims on the front by mistake. To install aftermarket rims, just get a 10mm wrench & unbolt it. Problem fixed!
Old Dec 31, 2007 | 02:16 PM
Escobar's Avatar
Escobar
https://my350z.com/forum/2003-2009-nissan-350z/197329-the-top-100-common-questions.html
look through that before you start another thread, it was the FIRST one.
Old Dec 31, 2007 | 06:15 PM
If you remove the bolt all the brake fluid will leak out.
lapham3
Oct 7, 2022 03:15 PM
issyz
Jul 2, 2017 03:04 PM
Tochigi_236
Sep 27, 2015 03:40 PM
