Im about to purchase a set of rims and was curious about the pros and cons or what might be better or worse about having a 10.5 over a 9.5 besides the obvious... like looks and the bigger lip on the rim.
What tire size are you planning on getting? If you are going to use the usual 275 then it is mostly up to you on how you want it to look. 275 on 10.5 rim might look a bit stretched.
it's heavier
it will hold wider tire
sometimes more concave
will stick out of the body more
it's jusy bad azz than 9.5 for sure.
you can brag about your wheel width that is 2 digits.
Thanks for yalls input, I just purchased some Maya ST5's 19x8.5 front, 19x10.5 in the rear, I have never seen anyone on this forum with the ST5's so ill be sure to post pictures. =) And I did go with the vredestein tires....
Thanks,
Cory
i'm thinking about getting the vredesteins also...how are they working out for you so far? guess it might be too early to tell
