rolled the fenders, thinking of going +4 offset in the rear.
Jan 5, 2008 | 08:25 PM
i have about an inch or more clearance between my tire and fender after the roll. thinking of going gangsta in the rear with a 20mm spacer, essentially making it +4 in the rear. this too much? maybe a 15mm at +9 might be wiser. any advice?
Jan 5, 2008 | 09:43 PM
whats the wheel width and tire size
Jan 5, 2008 | 10:37 PM
Quote:
10.5", 275/35/19, i think either +4 or +9 would work but i might want to do a 295/30/19 in the future.
Jan 6, 2008 | 01:07 AM
If you have an inch or more clearance, then run a 20-25mm spacer.
Jan 6, 2008 | 01:38 AM
i have a +10 offset and its pretty good..i think +4 might b a lil too much as far as it making it seem too beaner gangsterish
Jan 6, 2008 | 03:35 AM
Quote:
my advice is like killing a cochroach with a nuke, but just get the wheels you want, then MAKE them fit! i've got a porta-power that flares fenders nicely.
Jan 6, 2008 | 04:07 AM
Quote:
I agree... I would sell the wheels and get new ones with the appropriate offsets. Always the best solution imo.
Jan 6, 2008 | 06:51 AM
I say 15 if you wanna be safe, and 20 if you wanna be gangsta. Look at this space you created by rolling your fender.
Jan 6, 2008 | 07:03 AM
Quote:
gangster would be a lower offset,not higher offset
Jan 6, 2008 | 07:35 AM
^^I'm talking about the size of the spacer, not the offset. As in 15mills which would give him a 9 offset vs 20 mills which would give him a 4 offset.
Jan 6, 2008 | 07:43 AM
o ok then im with ya..but too aggressive for me
Jan 6, 2008 | 10:18 AM
Super Moderator MY350Z.COM
Quote:
Doesnt matter , we all know gangsta is stupid. Isnt the definition of gangsta = f%cking idiot.
Jan 6, 2008 | 11:32 AM
Do it! Daytona350z has -5 offset with pulled fenders.
I'm thinking about adding 20mm spacer and going with +2 in the rear!
Jan 6, 2008 | 02:28 PM
I'm almost touching with my stance and 10inch wheels..
Jan 6, 2008 | 05:38 PM
I've seen a 18x10.5 +0 slammed on stance and no rubbing on a rolled fender.
Jan 6, 2008 | 06:23 PM
i think im gonna go with a 20mm. the fender was rolled very very very well, almost too well. gonna need something aggressive to fill in the well.
Jan 6, 2008 | 06:30 PM
ur gonna need some camber and other things..you'll be way outta spec and have some premature tire wear
Jan 6, 2008 | 10:25 PM
im not gonna need any more negative camber then what i already have.
Jan 7, 2008 | 12:00 AM
o didnt know you already had neg camber..
Jan 7, 2008 | 05:10 AM
You already have negative camber stock. You have even more when you lower. I have a 1.5" drop on the rear and I'm at -2.5 degrees camber.
