Please Help. Wheel Spacers...
Old Jan 10, 2008 | 03:21 PM
  #41
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by Dave 90TT
Studs are a different thread pitch, so you would have to get different lugs and locks. SPLParts sells good quality lugs on their site, as well, but you do have those nice shiny black ones...
I actually bought my spacers from someone off this site, but there are a couple of places that sell good quality spacers. Performance Nissan does, as well as many of the vendors on here.
Dave
Thanks Dave. Aren't you running the shiny neo color ones?
Old Jan 10, 2008 | 03:41 PM
  #42
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
I am....they look good!
Old Jan 10, 2008 | 03:50 PM
  #43
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Bling! Bling! Baller!
Old Jan 19, 2008 | 07:48 AM
  #44
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Bump!
So right now I'm looking at 5mm spacer up front and longer wheel studs.
Any more info about the rear would be helpful.
Old Jan 21, 2008 | 09:33 PM
  #45
Vertex350's Avatar
Vertex350
It looks like the rear BBK would clear fine without the spacers. In fact, when the S1's were on Rickdogg's car it clears his BBK. Why don't you just shoot him a PM to be sure?
Old Jan 21, 2008 | 10:25 PM
  #46
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks and I have tried IMing him. We didn't end our transaction on the best terms.
Old Jan 21, 2008 | 10:28 PM
  #47
Vertex350's Avatar
Vertex350
OIC... good luck with that.
Old Jan 21, 2008 | 10:34 PM
  #48
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Not a problem. Thanks for your help.
Old Jan 22, 2008 | 05:01 AM
  #49
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
you cannot compare clearance on one brake kit vs another - each brake kit has its own clearance requirements
Old Jan 24, 2008 | 02:06 AM
  #50
Robert_K's Avatar
Robert_K
Didn't Go Cheap
OK... I'm gonna go with the Ichiba 5mm front. Figured 5mm on the rear should clear the ST-22 & 15mm might be too big (since I can't check). So I'm gonna do a 10mm on the rear.
Thanks everyone for your input!!!
Old Jan 24, 2008 | 10:40 AM
  #51
redlude97's Avatar
redlude97
What tire size are you running in the rear? With a roll, a 15mm spacer will clear easily, you could even go 20mm if you wanted it to be aggressive
Old Jan 24, 2008 | 11:03 AM
  #52
Robert_K's Avatar
Robert_K
Didn't Go Cheap
I don't want to go aggressive, I want to clear my BBK. As far as the tires size; 285/30-19 As posted in Post #1.
Old Jan 24, 2008 | 12:35 PM
  #53
redlude97's Avatar
redlude97
Maybe I missed it
Can someone give some sound advice. Below are the specs of my wheels. What size spacers do you think I'll need to clear the StopTech BBK. I'm looking at the Project KICS Wide Thread Spacer; Click Me.
FYI: I'm in Kuwait and can't print out the StopTech Caliper sheet to check for fitment.
Wheels: Work Meister S1 3-piece
Front Sizes and offset: 19x9.5 R Disk +24 offset
Rear Sizes and offset: 19x11 R Disk +36 offset
Brakes: StopTech F&R BBK
Front Sizes: 14" (355mm) ST-40 4-Pot
Rear Sizes: 13" (328mm) ST-22 2-Pot
Old Jan 24, 2008 | 02:29 PM
  #54
MyNismoRoadster's Avatar
MyNismoRoadster
Originally Posted by Z1 Performance
I run the Ichiba spacers on my own car - they include longer studs and are cnc'd from billet aluminum
The Ichiba spacer are nice, but the cheap hub bolts have alot to be desired, they dont have the good corrosion resistance like the factory ones and H&R since they arent aluminized. Ive run into alot of rust with those hub bolts, snap a few of them also because when they were being loosened they became cross threaded somehow on its way out.
What i do agree with is your statement about using spacers that have hub bolts built into them, i dont feel as those are a good setup either as many of them like Project Mu ones are not hubcentric and allows the hub bolts to carry all of the car's loads instead of the hub.
One thing is that many spacers below 20mm does not allow enough thickness to clear the factory hub bolts so you can mount your wheels on. That's unless your wheels have the hollow sections in between the hub bolt holes for the excess stud length to clear.
Old Jan 24, 2008 | 05:39 PM
  #55
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Maybe I missed it
Don't I feel like an ass. Sorry.
Old Jan 25, 2008 | 03:58 AM
  #56
Z1 Performance
Former Sponsor
I hear ya - so far I have not had any rusting issues with them, though I did have one set where the knurl just didn't want to grab and we stripped a whole bunch trying to install them. Contacted Ichiba, and they expressed us out a new set free of charge and without hassle, which, as you probably know nowadays, is alot I haven't snapped any yet though, or had any other issues. We've used H&R ones too, and they've worked out great as well (we run them on both our BMW IT cars)
Old Feb 4, 2008 | 04:58 PM
  #57
Rekinyze's Avatar
Rekinyze
Anyone know where I can find a good How-to guide on installed rear wheel spacers on a Z???
Thanks for your help!
Old Mar 14, 2008 | 12:07 AM
  #58
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks everyone for the info! The BBK came in, Link, and has been installed w/o any spacers. Guess everything works perfect and looks awesome. I'm going by my installer's shop Saturday to check them out.
Obadabot
Jun 18, 2023 11:31 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
