Please Help. Wheel Spacers...
Old Jan 9, 2008 | 06:16 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Question Please Help. Wheel Spacers...
Can someone give some sound advice. Below are the specs of my wheels. What size spacers do you think I'll need to clear the StopTech BBK. I'm looking at the Project KICS Wide Thread Spacer; Click Me.
FYI: I'm in Kuwait and can't print out the StopTech Caliper sheet to check for fitment.
Wheels: Work Meister S1 3-piece
Front Sizes and offset: 19x9.5 R Disk +24 offset
Rear Sizes and offset: 19x11 R Disk +36 offset
Tires: Yokohama Advan Sports
Front: 255/30-19
Rear: 285/30-19
Brakes: StopTech F&R BBK
Front Sizes: 14" (355mm) ST-40 4-Pot
Rear Sizes: 13" (328mm) ST-22 2-Pot
Old Jan 9, 2008 | 06:19 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
5mm up front as was mentioned in another thread
rear, no idea, never used that rear wheel before
Old Jan 9, 2008 | 06:27 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks for the front. I'm just not understanding wheel offsets. So by adding a 5mm spacer to the front, the front offset, theoretically, becomes +19 or + 29?
Why is this (rear wheel) offset so unusual? Is there a plus for having a +36?
Old Jan 9, 2008 | 06:31 AM
Z1 Performance
Former Sponsor
+24 offset with a 5mm spacer makes it a +19.
wheel spacers move the wheel outwards, so it reduces the offset to a figure closer to 0
as far as the rear wheel, I've never sold that size - every 11 inch S13P we've ever sold was the +23 rear
Old Jan 9, 2008 | 06:35 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
OK. Understanding that. Would the 19x11 +23 clear the ST-22 caliper? If not, what size spacer would it need?
Old Jan 9, 2008 | 06:44 AM
Z1 Performance
Former Sponsor
sorry I can't say for sure - Moroccon Mole will be able to answer you at some point as he has the 19x11 +23 rear and we just sent him the rear brake kit a few weeks ago - he already has the front kit. I just haven't used that particular combo at a car here at the shop yet to know first hand
Old Jan 9, 2008 | 06:46 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks for the info you have provided. Understanding offsets a bit more. One last question: What the downside to a wheel spacer?
Old Jan 9, 2008 | 06:54 AM
dutchboy350Z's Avatar
dutchboy350Z
Finally some go
As long as they're installed properly and are hubcentric there's no real downside. I've had mine on since last may (8,000 miles) and have had no problems at all (I have 20mm Project Kics on the rear).
BTW ... an 11" width with +36mm offset doesn't sound right. My rear wheels have a 10" width and came originally with a crappy +37mm offset.
Old Jan 9, 2008 | 07:02 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well that is what I have and no idea why Rickdogg (orginal owner) went with a +36. If I had known this was going to cause so much trouble I would've never bought them. He assured me these wheels would clear a 14" BBK.
Old Jan 9, 2008 | 07:11 AM
DustinZ33's Avatar
DustinZ33
Order the 5mm for the front as Z1 said. Try it on the rear to see if it clears. If so, then buy another set of 5mm for rear. If not, then go with a 10mm. Or see if you can borrow a set of 5mm from someone.
Old Jan 9, 2008 | 07:19 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Well, as mentioned, I'm in Kuwait so "I" can't try anything right now. I'm just making sure I have EVERYTHING for when I come home for R&R.
Old Jan 9, 2008 | 07:46 AM
DustinZ33's Avatar
DustinZ33
Oh. I missed that the first time. I'm sorry.
Old Jan 9, 2008 | 07:55 AM
Z1 Performance
Former Sponsor
there is no downside to a GOOD set of spacers.
Good spacers, to me, are not only hubcentric, but they also include longer studs. You press the old, short studs out and install the new longer studs. Takes a little while to do, but to me, it's the safest way. The ones I would not trust (personally) are ones that bolt to the hub, but that is just my own personal preference
Old Jan 9, 2008 | 08:46 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
So the Project KICS are a good investment, IYO Adam?
Old Jan 9, 2008 | 08:49 AM
Z1 Performance
Former Sponsor
never used em, so I know nothing about them
if they have longer studs included, they will work fine. If they bolt to the hub themselves, it's not what I'd personally use
Old Jan 9, 2008 | 08:54 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Here is what I found:
Originally Posted by Mackin Industries Website
Direct from Japan, the KICS wide thread spacers are used to bring out the wheels of your car outer to give aggressive look and close the space gap. The KICS wide thread spacers are also used to clear spacing between your big brake kit from the wheels. These spacers come with new studs already installed with all necessary hardware. Available in 15mm, 20mm, 25mm, and 30mm for most popular Japanese vehicle applications (1.5mm / 1.25mm).
http://www.mackinindustries.com/wm/k...eadspacer.html
Old Jan 9, 2008 | 08:58 AM
Z1 Performance
Former Sponsor
not what I would use on my own - I prefer the ones that use longer studs vs reusing stock studs and bolting to them
Old Jan 9, 2008 | 09:01 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks for all the info Adam. I'll do more research in the morning.
If anyone happens to have any more suggestions, info, part links, etc... please share. THANKS!!!
Old Jan 9, 2008 | 09:03 AM
Z1 Performance
Former Sponsor
I run the Ichiba spacers on my own car - they include longer studs and are cnc'd from billet aluminum
Old Jan 9, 2008 | 09:24 AM
DustinZ33's Avatar
DustinZ33
I guess it's personal preference. I'm getting the kics, which bolt on and have seperate studs. I've been told by a couple people that they think the kics are safer than slip spacers. One of which tracks his car often and he's had no problems yet.
