******will 295/40/20 Tires Fit On Rear?????
anyone out there know if this set up is possble? I know mustangs have this configuaration, but will it fit my Z? Trying to fill the gap between the fender and the tire....
stock axis mod 7s 20x10 and 20 x 8.5 fronts look ok 245/35/20, backs now are 275/30/20 and there's a big gap between fender and tire....want wider and to close gap....
These are the measurements of the sidewall of the tire with dif widths of tires with the same series tires "30". what is ur offset on the wheels?
275/30/20 = 82.5mm //// your current thickness
285/30/20 = 85.5mm //// wider tire and lil thicker sidewall
295/30/20 = 88.5mm //// wider&thicker but might rub dependingon offset
295/40/20 is way to thick/////118mm
295/ 40 R20, are you kidding me? The Z is a sports car not a monster truck! W/e you do, do not get that size. It will look like crap. Also a 295/30 R20 in rear will keep almost exactly the same overall diameter of the stock wheel/tire combo. I am running 20X10.5 in rear +22 with a 295/30. I do not feel that a 275 width for a 10.5 inch rim is enough, but I am one who cannot stand stretched tires. I am lowered on Tanabe GF210's. I believe it is about 1 inch lowered or 1.2". It did rub! I rolled my fenders and now have about 1/2" clearance.
Here are a few pics to give you an idea... sorry if the pics are a lil big.
__________________________________________________
Originally Posted by gsingh350Z
Quit posing with your car.
