Unofficial Enkei Wheels Thread
Old 10-12-2014, 02:26 AM
  #2241
Underscore_Hero
Underscore_Hero's Avatar
Ok, I think I'm good for offset, hopefully.
How's this setup:
RPF1's w/ Hankook V12's
F: 18x9.5 +15 w/ 245/40/18
R: 18x10.5 +15 w/ 265/40/18
Not lowered, rear fenders not rolled.
Old 10-12-2014, 03:20 AM
  #2242
mr. sparco
mr. sparco's Avatar
How's this setup:
Well, you're lucky to have picked the most common setup of rpf1s for the 350z. So you're good to go with offsets and width. The weaksauce point is where you're running narrow 265/40s. Depending on your alignment you might still rub on hard rebounds.
Old 10-12-2014, 03:51 AM
  #2243
Underscore_Hero
Wouldn't narrow tires have less chance of rub? They have a light stretch iirc.
That's the widest the Hankooks will go for 18"
Old 10-12-2014, 04:36 AM
  #2244
terrasmak's Avatar
Received 2,314 Likes on 1,666 Posts
What Hankook tires are you wanting to run?
Old 10-12-2014, 04:50 AM
  #2245
Underscore_Hero
Hankook V12 Evo's.
I like them on my other daily.
Old 10-12-2014, 05:37 AM
  #2246
terrasmak's Avatar
Hankook V12 Evo's.
You can easily get a 275/40-18 and 255/40-18 in those tires for those wheels. It's what I ran on the street back in the day.
You will need a roll in the rear and trim the front fender liner screw
Old 10-12-2014, 06:22 AM
  #2247
Underscore_Hero
Damn...found them.
Apparently I have no idea how to browse tire rack :/
Thanks bro!
Old 10-12-2014, 11:53 AM
  #2248
mr. sparco
mr. sparco's Avatar
Less chance, doesn't mean won't. Your alignment specs will be a big factor. Why risk fender damage due to something as simple as rolling?
Old 10-12-2014, 04:23 PM
  #2249
Underscore_Hero
I do plan to roll the rears.
But I was just noting the fact that thinner tires with stretch will rub "less" than wider tires. I'm happy as long as they don't rub the inner fender and wheel well.
Only real issue now is that the 275's are $70 more than the 265's (which are on sale)...time to save a lil more I guess.
Old 10-12-2014, 09:27 PM
  #2250
nizmo_0385
nizmo_0385's Avatar
Do rpf1 18x9.5 15 clear oem brembo upfront? Thinking of running these on my nismo and ditching the oem double stagger.
Old 10-13-2014, 04:44 AM
  #2251
Bmurray350z
Bmurray350z's Avatar
yes they do. its close but they do.
Old 10-13-2014, 05:00 PM
  #2252
jdepe
jdepe's Avatar
18x10.5 +15 275/40/18 wont rub the rear. my alignment specs is stock and I don't have any issues.
Old 10-13-2014, 05:02 PM
  #2253
Underscore_Hero
What tires you run?
Old 10-14-2014, 06:19 AM
  #2254
terrasmak's Avatar
Mine started rubbing at 10.5 +25 , with a roll I was running at 10.5 +10 with that tire size.
Old 10-15-2014, 03:40 PM
  #2255
jdepe
jdepe's Avatar
I'm running BFG gforce sport comp2, haven't decided on what tire for autoX yet. been busy with school. I did pick up some 5MM spacers for the front and plan on running them with arp extended studs up front. The 18x10.5 +30 rubs the front spindle sightly on aggressive turns. Running 18x10.5 +30 275/30/18 up front.
Old 10-15-2014, 05:08 PM
  #2256
Underscore_Hero
I thought you were running +15.
Old 10-15-2014, 07:53 PM
  #2257
jdepe
jdepe's Avatar
18x10.5 +30 275/35/18 front, 18x10.5 +15 275/40/18 rear. nt03, bfg gforce sport comp2 tires.
Old 10-18-2014, 12:09 PM
  #2258
JTeeAre
JTeeAre's Avatar
I'm planning on picking a set of Raijins 18x9.5 +15.
I want to do a square tire setup at 275/40 but from what ive seen here it might be easier to run a 35 series in the front and 40 in the back.
Or will a 40 series all around work fine too?
Old 10-18-2014, 02:35 PM
  #2259
Bmurray350z
18x9.5/10.5 +15 RPF1s
255/40 275/40 Hankook V12 Evos
Old 10-18-2014, 03:46 PM
  #2260
mr. sparco
mr. sparco's Avatar
RPF1s look best on your car, either the black or silver.
Quick Reply: Unofficial Enkei Wheels Thread
