View Poll Results: Size tires?
275/35/19R 255/35/19F
64.71%
275/30/19R 255/30/19F
11.76%
285/35/19R 265/35/19F
11.76%
285/30/19R 265/30/19F
11.76%
Voters: 17. You may not vote on this poll
poll: tires on 8.5 and 9.5 wheels.
Wheels are going to be 19 inches and fronts are 8.5's rears are 9.5's offsets are 35 but next week im putting on 15mm spacers so thats gonna come into play. thanks for the vote
http://www.tirerack.com/tires/tires....1=yes&place=14
also what are your views for this tire? its cheap but the survey results look pretty decent for the price?
Of those choices, the only one that makes sense is the first one. the 30 series are not the right diameter.
Your other 35 series choice will be pinched but would work but i wouldnt do it.
However i didnt pay attention to your offsets
ok i dont know much about tires so throw the 30 sidewall out of the equation? And you think the 285 is a little too big is that right? pinched? what does that mean thanks.
with a 285 tire on the rear is that gonna make them bulge out or will it fit pretty good? I also want the best tires for no oversteer and very little understeer thanks for the help thus far guys.
285/35/19 falken 451's
Originally Posted by black06z
tire rack suggests:
245/35 front
275/35 rear
245/35 front
275/35 rear
i was just thinking about keeping the 20mm stagger from stock? wouldnt that be best or not? wouldnt that setup increase understreer? sorry for my ignorance but like i said dont know much about tires anything that has to do with suspension or handling lol. thanks for the patient good replys so far.
I believe you mentioned the other thread that you were getting an aftermarket suspension. If you get a coilover with adjustability, then you can dial in your height and dampening settings to help reduce/increase oversteer/understeer.
I selected the first choice: They will fit better, the extra width will just add weight and rolling resistance unless you really need that traction, in which case you should get some better tires.
