225/40 R18 and 245/40 R18
Old Jan 20, 2008 | 09:57 PM
massy75's Avatar
massy75
Default 225/40 R18 and 245/40 R18
I am an owner of an 35th anniversary Edition.
I would like to change oem tires on stock wheel with a set of toyo R888...
Does these size fit oem wheels properly ?
Thanks in advance,
max
Old Jan 20, 2008 | 10:09 PM
r_seng's Avatar
r_seng
yes it'll be fine.
Old Jan 20, 2008 | 10:52 PM
terrasmak's Avatar
They fit fine , if they offer a 255/40 i would suggest the 245's in the front and 255's for the rear.
Old Jan 21, 2008 | 05:25 AM
660dragfan's Avatar
660dragfan
Talking
I went with the same sizes that you are asking about. Then I changed the rear to a 265/35/18. I work at a Tire shop on the weekends. I will go a little wider on my fronts soon. You will be fine.
Old Jan 21, 2008 | 09:31 PM
massy75's Avatar
massy75
Thanks a lot!!
Old Jan 21, 2008 | 10:54 PM
SniperHunter's Avatar
SniperHunter
Woah, woah, woah. I hate to rain on your parade, but that is NOT a proper size to run. These wheels will give you an error of 3.4% on your speedometer. When your car displays 60, you're going 58. This isn't a within-spec tire choice.
Old Jan 21, 2008 | 11:00 PM
Manu's Avatar
Manu
Good to see another owner from Switzerland
Agree with the above post, your overall tire diameter will be smaller so your car will use more gas. On the upside, you will get better acceleration .
The Brickyard Rat
Jun 17, 2005 07:41 AM
ejmills2000
Sep 3, 2004 05:49 PM
lowrider
Aug 26, 2004 10:48 AM
ZZ3.5
Feb 17, 2004 07:42 PM
ztom
Aug 2, 2003 05:18 PM
