18x10 +22
Originally Posted by JETPILOT
With 18's you will need 275/40/18 in the rear.
https://my350z.com/forum/media-share/224050-ppw-and-volk-racing-time-attack-wheels.html
You can run whatever you want. They are still not close to stock diameter. 275/40/18 is stock diameter.
JET
JET
235/50 R17 is also a stock diameter and almost a half inch smaller in diameter than a 245/45 R18 tire. Tolerances aren't that close. Therefore, 275/35 R18 is within acceptable (+/-3%) limits.
Bigchef66 - I am using four 18x9.5 +22 wheels no problem. It is only the front that you should be concerned with, because that wheel turns. Your wheel would stick out 6mm (1/4") more than mine on the inside and outside. I'm not sure if that would fit or not.
they will fit no problem. I had 18x10.5 +15 front and back with 265/35 tires... no rubbing, no fender rolling, and dropped down with stance coil-overs. They fit fine on a G and a Z.
azndoc
Wheels Tires
Oct 10, 2015 02:59 PM
