HEATED! Need some help
Whattup,
So today I finally find a shop around my area to install my Ichiba 20mm wheel spacers. I drop my car off this morning hopeing everything will go well, but then i get a call saying that the spacers don't fit right on the hub (theirs a little gap in between) and he calls me over to take a look. So then he says he can get it to fit by grinding down the inside of the spacer, so i leave. But nope all else fails and he gives me a call saying that these spacers will not fit on the car ?!?! And now im really mad because i spent over $200 for these spacers that now don't work for my car when they are specified that they do. Not to mention the cost the shop is gonna charge me for labor. And a different shop that i brought my car too before said that installing these spacers was going to be a 10 hour job and cost over $500?! So can someone help me out here and tell me if i bought the wrong spacers, and now i gotta buy brand new ones and i dont know which to buy. I really want my rims to sit flush and just want to get this **** over with.
Alright thanks for listening,
Sean
Heres a link to the spacers:http://www.optionsauto.com/prodinfo....r=ICH-NS-50220
Sean
Is this really a job that requires a shop? I'm pretty sure that your trunk has all the tools necessary to get the job done.
try measuring the bore on one they havent ground yet, and make sure its 66.2. Also make sure they have removed the keying bolt from the front rotors, because maybe they are trying to grind a relief into the spacer for it?
Alright well not the real hands on kind of guy when it comes to installs, and 2 shops have told me its a hard job so i dont know ? They say it flat out dosent fit against the hub. Someone wanna help me out here.
wtf, you don't need to take off the rotors to install spacers! Not sure if the 20mm spacer has built in studs or not, but even replacing the extended lugs wouldn't involve taking off the rotors....
maybe that's the problem? the ichiba spacers have 10 holes, but you're suppose to take out the oem studs and replace them with the extended ones.
IF the rotors where off thats exactly what he was tring to do.Jack your car up take the tires off and slid the spacers on then replace your tire.ALA KAZaaammmmbiotch your mechanic is ownedddddddddddd.
Yeah, just get your car out of the shop asap and read up in the DIY section for a few minutes, you'll figure it out. But while they are under there make sure they get the muffle bearings back into place and replace the headlight fluid. It's the least they can do.
If you don't take advise the first time, why make another post?
https://my350z.com/forum/brakes-and-suspension/331948-just-went-to-my-local-shop.html
Alright, yeah thats what i thought. They must be some dumb *** guys, maybe its cuz its mostly a honda shop lol...Im def gonna find another shop, thanks
https://my350z.com/forum/showthread.php?t=331948
If you just did a little reading before taking your car in you would have known how easy it is to install these spacers.
Always do your homework. If you don't, you're begging to get screwed over.
Alright, I understand. But what do I do now because if I attempt to do it myself, wont the spacer not fit correctly on the hub because they showed me space in between ?
