Wheel Spacer loss of power?
hey i'm thinking about buying these https://my350z.com/forum/socal-marketplace/340608-fs-2-25mm-spacers-built-in-studs-w-rings.html and was wondering if there would be a noticable loss of power since i'm adding weight to the rear wheels. I have 19' g35 rays rims and would like the rear to fit more flush. Also would the handling get better since rears would have a wider stance? thanks for the help, i searched and didn't find any info on this topic so no need to go nuts and tell me to search.
I do find it interesting that people spend a lot of $$ buying lightweight wheels, and then add weights (spacers) to these expensive wheels.
I suppose the way to dismiss this concern is that you add weight to the axle and not the wheel.
--Spike
I suppose the way to dismiss this concern is that you add weight to the axle and not the wheel.--Spike
Originally Posted by Ilov350ZEE
i think hes talkin about the weight of the wheels it will be farther off center making more heavier.
Originally Posted by dutchboy350Z
How is being 25mm further out going to make it "heavier"? Your post seems a bit more "childish" and, more importantly, uninformed than davidv's.
davidv is an asshat, all he has to contribute is smart-*** one-liners(look up all his posts)
this is true, although they will still add rotational mass.
Originally Posted by first350
the spacer is near the center of rotation for the wheels...so it's rotational mass isn't as big of a factor.
Then again maybe you don't know what the definition of "rotational mass" is.
I think you were better off just lurking here.
I just had mine installed. Coming from a guy who's peculiar and **** retentive to the point where I notice every little obscurity...
Didn't notice jack sh*t different with the spacers in terms of power. Handling, on the other hand, does feel improved.
