Stock 18" wheels, how wide can I go with tires?
Old Mar 6, 2008 | 03:20 PM
RandyK1's Avatar
RandyK1
Default Stock 18" wheels, how wide can I go with tires?
I have a 06 base and I want to get some new "better then stock" tires. My question is: what is the widest size I can go with on the stock 18" wheels and not rub? Also, if I go down to 40 insted of 45 will it mess with my spedo? Thanks, Randy p.s. No smart a$$ answers please, I already did a search and if I knew the answer I would not have asked the question's
Old Mar 6, 2008 | 03:24 PM
kno's Avatar
kno
im in the same boat how wide can you go ive heard up to 275 rear and 245 front i dunno if brand differ in sizes tho
Old Mar 6, 2008 | 03:27 PM
sk26dett's Avatar
sk26dett
you didn't search, there's tons of info out there.
Search through this
https://my350z.com/forum/wheels-and-tires/265346-widest-tire-for-nissan-oem-8-5-rear-track-wheel.html
Short answer: 275/40/18 will "fit" in the rear
Old Mar 6, 2008 | 03:28 PM
sk26dett's Avatar
sk26dett
and this
https://my350z.com/forum/wheels-and-tires/333867-anyone-with-265-or-275-rear-but-oem-18s-3.html
Concave's Avatar
Concave
check out tire specs for the sizes you are thinking about.
im going with a 245/40 on a 9.5" wheel. (18")
in my opinion, if you go with thick tires on the 18", it makes the rims look smaller, thats why i went with a stretched look.
its all about deceiving the eyes so ppl dont go
"ew is thoses sum 17s on you whip???"
Old Mar 6, 2008 | 03:34 PM
grcunningham's Avatar
grcunningham
Has anyone run 225/40 & 245/40/18's on their stock Grand Touring wheels? Any issues with fitting the TPMS sensors due to the shortened side wall?
Old Mar 6, 2008 | 03:39 PM
Equinox's Avatar
Equinox
235/40/18 front and 255/40/18 rear should work good on stock sized rims.
Old Mar 6, 2008 | 06:26 PM
miyk's Avatar
miyk
not on the OEM wheels your not, well in the rear atleast.
Old Mar 6, 2008 | 07:29 PM
z-u-later's Avatar
z-u-later
SEARCH
Old Mar 6, 2008 | 07:36 PM
The question is asked at least once each week. I have no patience with lazy.
Old Mar 6, 2008 | 07:48 PM
Spike100's Avatar
Spike100
Here is how you select a tire size (width and aspect ratio):
Step 1: Refer to the tire manufacturer’s specification chart to determine the correct tire width (minimum to maximum section width) for your wheels.
Step 2: Refer to Nissan’s specifications to determine the correct aspect ratio for the width you select above. That gives you the correct overall diameter for your tire.
--Spike
Old Mar 6, 2008 | 09:07 PM
WSchli1672's Avatar
WSchli1672
255/45/18 and 275/45/18 (It was a miss type)
A good start.
Old Mar 6, 2008 | 09:43 PM
Spike100's Avatar
Spike100
Originally Posted by WSchli1672
255/35/18 and 275/35/18
A good start.
Why do you suggest F 255/35-18 and R 275/35-18?
- The aspect ratio (35) for these widths is shorter than stock overall diameter. Wouldn’t F 245/40-18 and R 275/40-18 be a better size for the Z as to overall diameter?
- 275mm section width is too wide (past the tire manufacturer’s specification) for the 2006 Base model’s stock rear wheel width.
--Spike
Old Mar 9, 2008 | 05:55 PM
WSchli1672's Avatar
WSchli1672
--Spike
I just checked with Nissan and they said suggested to stay with the original size "Front 225/45R18 and Rear 245/45R18" and don't use anything else , as it can cause problems down the road. So I'll take their word naturally and I stand corrected, and my new Toyo Tires for my rays are the stock size. I was about to actually buy the other size tires, by the so call recommendations of a tire company, but thank goodness I did go to Nissan first. I have a very good relationship with them.
Old Mar 9, 2008 | 07:07 PM
RandyK1's Avatar
RandyK1
Well, I guess I am going to strech it abit and go with 235/40/18 front and 255/40/18 rear. I wouldnt think that they would be oversized enough to cause a problem (I hope) Randy
Old Mar 10, 2008 | 05:21 PM
Spike100's Avatar
Spike100
The size you mention will work fine on your Z. But, here are some other thoughts…
As to overall diameter:
235/40/18 front and 255/40/18 rear isn’t oversized, in fact it’s undersized by about ½ inch when comparing overall diameter to stock tires.
If esthetics is important to you, mounting tires with a smaller circumference may not provide the look you want. The Z’s fenders’ outline is sculpted for a larger tire, and even dropping the car may not look right to some when mounting tires with less overall diameter.
If performance is important, then a shorter tire may be what you want because you get slightly better acceleration (but only at lower speeds).
As to tire width:
10mm is only 0.39 inches. That difference when comparing a tire’s section width is negligible (especially considering that the actual tread difference is even less).
I would consider these sizes on stock 18” wheels: F 245/40-18 and R 245/45-18”.
  1. This arrangement is the stock specification for overall tire diameter.
  2. It will look right on the Z (fender openings) even if you drop the car a ½ inch.
  3. 245’s on the front provide great handling. You get neutral steering with fast and secure turn-in , and this width doesn’t suffer from bump-steer or wandering at highway speeds.
--Spike
Old Mar 11, 2008 | 07:29 PM
RandyK1's Avatar
RandyK1
What I would like is for the tires to stay the same hight , but be wider on front and back. Any one have any size ideas?? Thanks, Randy
Old Mar 11, 2008 | 08:50 PM
Spike100's Avatar
Spike100
Why do you want the tires all the same height?
--Spike
Old Mar 12, 2008 | 05:13 AM
RandyK1's Avatar
RandyK1
I ment that want the new front tires to be the same hight as the stock front and the rear tires to be the same hight as the stock rear tires. I just want wider tires with out the car looking goofy. This is my first real sportscar and I really dont understand tire sizes a whole lot. What would look nice and put more tire print on the road?? Thanks, Randy
Old Mar 12, 2008 | 03:59 PM
Spike100's Avatar
Spike100
OK... got it.
If you have stock wheels, and the wheels are 18x8”, here are two setups that are exactly stock as to height:
Setup 1:
Front 225/45-18” and Rear 245/45-18”
Setup 2:
Front 245/40-18” and Rear 245/45-18”
Setup 1 is stock and has a slight amount of under-steer. Setup 2 uses wider fronts and has neutral-steer.
If you want to go wider, you should buy aftermarket wheels which give you many choices on tire width (but not height) depending upon the wheel's size.
--Spike
