Whats size spacers should i use?
I just bought a 04 350zr touring. I currently have 19x8.5 fronts and 19x9.5 rears both +45 offsets that I have from my 02 maxima. I know thay are not ideal, however if I could use them in the mean time, I think they will look nicer than the factory wheels. What size spacers would I need to use to push them out to the fender, if it is even possible to use my old wheels. Thanks.
Originally Posted by idwin
? did you search at all? depends on your tires also. i think you could easily run 30mm spacers,lol. those offsets totally suck.
Hey, instead of creating a new thread ill just jack this one
What is the best size to use for the stock wheels on the GT (front 18, rear 19). Im guessing 25mm for front? Is that true? What about rear?
/jack
/jack
I am planning on running 18x8"(front) with +45 offset using a 25mm spacer(essentially bringing the offset to a usable +20) and running 19x10"(rear) . Staggered widths and diameters. It is possible from what some other guys have told me on this site(thanks again 1nate7). I am just trying to use some wheels I already own to save some chedda. I purchased the matching 19x10's recently to specifically do this. the front wheels are coming off of my lexus is300.
I realize +45 offsets are far off, however I am just wondering what size spacer is needed. If I used a 25mm spacer all around (which doesnt seem too extreme) would that not be similar to a +20mm offset wheel? That seems like a fair comprimise for about $200. I didnt think I would need 45mm spacers, which I dont think even exist. Maybe my math is all messed up but a 45mm spacer would equal 0 offset, and a 35mm spacer would equal a +10 offset (if we were comparing same width wheels) The fact that my maxima wheels are wider (i beleive) at 8.5 front and 9.5 rear should favor me a bit too? 200 bucks sounds alot better than $3000 right now.
