New Rims Came In
Also, if you haven't seen them the weds lug nuts are pretty hot too. They're hard to find though, the best I could do was $150 a set from one of the vendors. I'm trying to find some pics.
Originally Posted by ncparamedic
How much were the Weds Moto?? They look almost identical to the RS's..do they carry these in the 19"?
Originally Posted by Motormouth
if you find pictures, let me know... I was going to run custom powdercoated blue lugs to match the stripe.
cheap. but no, 18s are the largest they go. and 10 inch is widest. PM sent
http://www.neweraparts.com/Default.a...&ProductID=448
Also, I think it was Gruppe S that quoted me 150 for a whole set.
Weds Sport Wheel Nuts are design to fit Weds Sport wheels perfectly and gives a better look to the rims. Their lightweight aluminium design lowers the rolling mass of your wheels and these nuts are often used for race purposes. Each set of four nuts comes with a removal tool. Also available with a locking head, they keep your wheels safe and sound.
They are made from A7075-T6 Aluminuim Alloy and weigh in at just 25grams each. Normal Wheel nuts are about 65 grams. They also have a small grip on the end to allow easy turning with your fingertips.
Awsome deal bro..congrats..make sure you and nizmo get some great shots when you get it cleaned
I definitely will. Motor start up the Weds Army thread!
if you got a good deal, you might be able to sell the fronts on ebay or something.
I honestly prefer a different face front and rear, so I would say ROCK them! the same concavity/size all around makes the front look odd IMO. you need a stagger; makes the rear look wider, etc.
also, with the 1 inch narrower rim, it will sit about 24mm farther in, so you could run a 15 or 20mm spacer in the front to push them out so they are flush as well...
Adam told me if i want to RETURN them i CAN, hey but i got good deal
^^ Remember once you mount them and drive on them they are used...if you wanted 9.5s all around, stick to it. Dont settle. Trust me..
BTW i got Muteki lugs, are those safe? or should i get wheel lock too?
I guess they're not that much different than anything else. I ended up ordering some bronze Muteki lugs that look exactly the same, but if this blue turns out to match well I may have to invest:
the website you showed it came out to 70 bucks for them. that is pretty good.
the blue weds look veeeeery close to the stripe color.
I will say Blue
the blue wed lugs look veeeeery close to the stripe color.
Are you sure, it looks like 38 dollars for 4 lugs to me?
EDIT: Yeah, $221.25 before shipping from the UK...
Dammit Motormouth! I've had these same exact wheels waiting to go on my Chrome Silver Z sitting in my garage since December!
Edit: Actually, mine are Bronze 18X9 20 and 18 X 10 18
once I take more photos (i.e. 'better' photos
) you will see, the gunmetal color really shines and sparkles.
even the most expensive Volks have more or the same amount of sets out there as these rims (except maybe the Progressive MEs).
LOL I didn't realize it was only for 4!! oh lord!
stay tuned!
