Confuse as to what tire size to get
Old Mar 19, 2008 | 12:02 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
I had 275's in the rear with a 9.5" wheel and +20 offset and I didn't rub. Haven't put the 285's on yet but im also going with a 5MM spacer so I will prolly roll the fenders. Go with the 245/40 and 285/35, you MAY have to roll your fenders slightly depending on how your lowered and your camber, BUT it will look way way better and very aggressive and nice. Do it the right way the 1st time.
Old Mar 19, 2008 | 12:25 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ u still got CR kai?
Old Mar 19, 2008 | 05:34 PM
Spike100's Avatar
Spike100
Originally Posted by Spoiled Z
they're size 18 wheels +20f and +18r ...I will be drop with tanabe gf this weekend my fenders aren't rolled
OMG I'm confused.....
I think there are members here you can help, but they will need to know the width of your wheels (front and rear) and how much drop you plan for your suspension.
--Spike
Old Mar 19, 2008 | 07:07 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
--Spike
she got XD9 18x9 + ? 18x10 +18 ( i forgot front offsets)
Old Mar 19, 2008 | 07:56 PM
Spike100's Avatar
Spike100
^^ Then 275's are the best choice (275/40-18).
285's on 18" wheels are not a common width in the correct overall diameter for a Z equipped with VDC.
295's on 18" wheels with 18mm offset will rub.
--Spike
Old Mar 20, 2008 | 08:17 AM
MyV6IsFast3r
--Spike
You are correct. The 285 are hard to find. If you get the 275/40 do 255/40 in the front. There are pics of that setup in the Rota Wheel thread. Looks way better than the 245/40, and im pretty sure VDC will be happy.
I don't have VDC and the Sumitomo (sp) HTZ III come in the 285 I want and area really good summer performance tire so that's what I went with.
Yep I still have the Work CR Kai, which I would like to sell and get soem XD9's but im not trying really hard to sell them.
Old Mar 20, 2008 | 08:21 AM
MyV6IsFast3r
She's go thte same offset she just has 18x10 all around with a 20MM spacer in the rear to make it -2.
Old Mar 20, 2008 | 10:25 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
18x10 all around?? XD9?? Hummm very interestin how that look will be.
Old Mar 21, 2008 | 10:19 PM
Mike M's Avatar
Mike M
Any opinions on this size?
I have some 18x9 and 18x10 XD9's on their way, and plan on going with KDW2's. Now I keep being told that the size to get is 245/40/18 and 275/35/18, I have an 05 touring with TCS no VDC.
Now from what I'm reading in here about 1/2 dif between sizes for correct traction control function etc I calculated that i Should actually get the KDW2 in 245/35/18 front and 275/35/18 rear which has a .8" difference in size vs the .7" difference the stockers have and they both have a 1.1 - 1.2" decrease from stock diameter so they are both 4.7% slower meaning at 60mph on the speedo I'll be at 57.5mph. This is all going off the miata forum calculator.
If I am correct then this would work out great as everyone is sold out in the 245/40/18 kdw2's.
Old Mar 22, 2008 | 09:59 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ you should be fine.
But IMO 35 profile really look good with really Low dropped or 19" otherwise u wil have gap between tires and ur fenders.
Old Mar 24, 2008 | 04:56 AM
Mike M's Avatar
Mike M
Define Low Drop?
From my math running those 35's will lower the car as is 1/2" as well as look alot better on the rear with the XD9's as most people say the 40 makes the rim look even smaller that it is.
At most I was thinking of running an H&R or Eibach spring and dropping the car maybe 3/4".
Old Mar 24, 2008 | 11:22 AM
theaxe1149's Avatar
theaxe1149
1010tires.com has the best tire calculator in the tech area.
offset calc also.
Old Mar 24, 2008 | 11:38 AM
Motormouth's Avatar
Motormouth
Originally Posted by DavesZ#3
I have 285's in the rear without any rubbing problems and no rolled fenders. You can't go just by the tire width, it's a function of width, wheel offset and how lowered the car is.
and camber settings (if or if not adjustable). I had 275s on a 10.5 +20 with no problems lowered a little over 1 inch.
Old Mar 24, 2008 | 11:40 AM
Motormouth's Avatar
Motormouth
most guys get 40 sidewalls with 18s. if you do a 35 on normal width tires you will be going 'negative' I don't know if TCS/VDC cares about more than just different front to rear, but I would check that as well (I don't have either!!! woot)
Old Mar 24, 2008 | 05:17 PM
terrasmak's Avatar
Either:
245/40 & 275/40 <--- Lager rear tire diameter looks goofy.
245/40 & 285/35 <--- Very close good looking diameter front to rear.
265/35 & 285/35 <--- What im going to be running this summer.
275/35 & 295/35 <--- Might have to roll the fenders, very meaty setup.
You forgot the 255/40 & 275/40 combo, doesnt look goofy at all.
Old Mar 24, 2008 | 07:02 PM
MyV6IsFast3r
Yep, I like this setup aswell....
DON'T go with a 35 up front, to skinny. If anything do the 255/40 & 275/40.....
Old Mar 24, 2008 | 07:32 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
i just got mine today.
Sumitomo's 40 profile.
wasn't htat huge.
perfect fofr my setup.
Old Mar 24, 2008 | 08:29 PM
  #38
Mike M's Avatar
Mike M
what about 255/40 front and 285/40 rear on the xd9's?
kdw2 don't come in a 275/40 for the rear.
Old Mar 24, 2008 | 10:18 PM
  #39
jdhuegel1's Avatar
jdhuegel1
275/40 and 245/40
I have 285/35R and 255/35F waiting to go on though. I think the 40 in the rear looks too big. Only rubs occasionally on a big bump. I have Eibach Sportlines.
Old Mar 24, 2008 | 10:21 PM
  #40
Spoiled Z's Avatar
Spoiled Z
jdhuegel1 - that looks nice
