had to say
Old Mar 25, 2008 | 09:57 AM
lowerlattitude's Avatar
lowerlattitude
Default had to say
I changed my rear rotors last weekend and ended up using a breaker bar to take the lug-nuts off. The factory lug wrench did not have enough leverage. I had to pull HARD to get get the nuts off ( HA HA ).
I got curious and found the standard spec for the torquing the lug nuts is about 80 to 90 ft/lbs. I put a torque wrench on the front wheel lug nuts and hit 140 ft/lbs before it went off the scale. UNBELIEVBABLE what an ***#$)*( and an impact wrench can do...
L-L
Old Mar 25, 2008 | 10:13 AM
VO...'s Avatar
VO...
Administrator
I always mount and torque my own wheels. Tire techs working min wage FTL.....
Old Mar 25, 2008 | 12:19 PM
Fletch69z's Avatar
Fletch69z
That's messed up...
Old Mar 25, 2008 | 12:21 PM
maxpowers's Avatar
maxpowers
Yeah - I use the impact gun to tighten them up a little, then follow up with a torque wrench. The impact gun makes it difficut to tell how tight they are.
savvy's Avatar
savvy
when i put my wheels on 90 still doesn't seem like that much force. i hit 90 relatively easy. I usually torque them down to about 100
Old Mar 25, 2008 | 12:30 PM
Spork's Avatar
Spork
+1
I go to 100ft/lbs.
Old Mar 25, 2008 | 01:16 PM
DraGonAlchemist's Avatar
DraGonAlchemist
you guys do know that with an impact gun they do sell special torqued sockets. .any rim only requires about 75-80 lbs. .anything more's a waste. .specially when u catch a flat and are trying to get the damn rim off. .B4 u even put the wheels back on and the lug nuts. .allways lube up the threads ahead of time for next times removal to be easier. .I like to use. .Bendix Brake caliper grease. .PInk stuff!!!
