Air valve/pin question
Originally Posted by Spoiled Z
I was wondering .... the air valve/pin inside the valve stem is that something that can be replaced?
yes it can be replaced, but if you have tpm stems then you need slightly different cores. they are a bit shinier than normal rubber stem cores--made from a different material to prevent corrosion issues. you should also consider running a plastic valve stem cap if you haven't already
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
