12mm spacers - where to find
Old Apr 16, 2008 | 12:59 AM
icydude's Avatar
icydude
Default 12mm spacers - where to find
I have looked high and low for 12mm slip on spacers with no luck.
anyone know where i can find 4 of them like these
Old Apr 16, 2008 | 02:24 AM
1redZ983's Avatar
1redZ983
i suggest you get the hubcentric spacers with the extended lugs. look on ichibausa.com or google it. ive had a bad experience with slip on spacers from my wheel almost coming off to broken studs. They dont hold as well as the hubcentric with extended lugs. ive had my hubcentric spacers on for a 6 months now with no issues.
but its really up to you on what you want.
Old Apr 16, 2008 | 11:29 AM
icydude's Avatar
icydude
I have 60 mm nismo studs on the car so bolt on spacers are out of the question
Old Apr 16, 2008 | 11:47 AM
JasonZ-YA's Avatar
JasonZ-YA
HAVE A LOCAL machine shop make you some...
- J
Old Apr 16, 2008 | 12:37 PM
JETPILOT's Avatar
JETPILOT
Only the 20mm and up are bolt on. They sell 15's and 10's that are slip on. I never heard of anyone selling 12's. You might have to buy a 15mm and have it milled 3mm. Definetly go hubcentric. I would never consider the ones you posted.
JET
Old Apr 16, 2008 | 12:42 PM
icydude's Avatar
icydude
The ones i posted are hub centered for a 66.06mm hub(size i need) but do not come in 12mm/.5" as i need.
Another person i know said to grind the studs off a bolt on and run the spacer bolted to the same lugs as the rin since i have the long nismo studs.
Old Apr 16, 2008 | 12:43 PM
JasonZ-YA's Avatar
JasonZ-YA
there you go JET.... ya thats a better idea... milling down some 15's... any local machine shop could do that...
I would have them mill down from the face though...you wouldnt want to remove from the back...doing that would kill bearing area on your studs (thickness for load transfer).
- J
Old Apr 16, 2008 | 12:46 PM
JasonZ-YA's Avatar
JasonZ-YA
thats a horrible idea...dont do that...
plus you wouldnt need to grind them off...you could press them out...but still....Jet's idea of milling down some 15mm spacers is the best option in my opinion....then again 15mm verus 12mm....humm i would find it hard to tell the 3mm difference...
-j
Old Apr 16, 2008 | 12:48 PM
icydude's Avatar
icydude
I am fitting 295's all all 4 corners of my car
they had to be 12mm exact
3mm means pulling the fenders that much more.
Old Apr 16, 2008 | 12:57 PM
JasonZ-YA's Avatar
JasonZ-YA
..wow....
well ya, i would think 15mm spacers milled down would be great...
- j
Old Apr 16, 2008 | 01:14 PM
JETPILOT's Avatar
JETPILOT
Wow... why would you do that? 295 all 4 corners?
JET
Old Apr 16, 2008 | 01:15 PM
icydude's Avatar
icydude
it's for a gtr
not a 350
Old Apr 16, 2008 | 01:38 PM
first350's Avatar
first350
JET
295 on all 4 corners is great! If I was limited in my rear, I would have run that...instead I run F295, R315's.
I love how a square tire set-up handles...very neutral.
Old Apr 16, 2008 | 01:40 PM
icydude's Avatar
icydude
Well i found what i will use
those simple slip on itchiba spacers with the hub centric ring.
Makes sense to pay slightly more and not have any god aweful vibrations later on down the road.
Old Apr 16, 2008 | 10:11 PM
smokedout350z's Avatar
smokedout350z
i have some universal 12mm spacers in the classified if interested..
Old Apr 16, 2008 | 10:38 PM
terrasmak's Avatar
How about just running 10mm spacers, the 2mm in the other direction couldnt hurt that much could it?
Maybe if you contact Ichiba , they could make them for you!!
Old Apr 17, 2008 | 10:47 AM
Triple8Sol's Avatar
Triple8Sol
Maybe he needs that for brake caliper clearance? If so, 2mm can make a big difference. With my Maya RT5 wheels, I had literally 1mm of clearance. With my PIAA SuperRozza wheels, I had maybe 3mm of clearance.
Old Apr 17, 2008 | 11:50 AM
icydude's Avatar
icydude
I need that clearance for the control arm
As is stands now
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
