Hubcentrinc Spacers Help Please...
Old Apr 22, 2008 | 09:33 AM
jak5b's Avatar
jak5b
Default Hubcentrinc Spacers Help Please...
Little Help Please....from Experience, Can Anyone Recommend Me A Dependable Hubcentric 15mm Spacer That Comes With Inbuilt Studs...i Tried To Read As Many Posts As Possible Related To The Subject, But I'm Still Bit Unsure...i Def Want To Make Sure There's No Vibration, And That They Actually Fit My Oem 19/18" Gt Rays...thanks!
Old Apr 22, 2008 | 09:35 AM
JasonZ-YA's Avatar
JasonZ-YA
I would say project kic's spacers. their 15mm have built in studs. I love mine...
problem is calling every shop online and seeing if they have them in stock..
- J
Old Apr 22, 2008 | 02:51 PM
Ruthless18x's Avatar
Ruthless18x
Concept Z has a **** ton.
Old Apr 23, 2008 | 05:17 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Project Kicks bolt on to your existing studs, Ichiba/H&R/Eibach replaces existing studs with longer studs - either type works just fine. I personally use the latter type as it makes me more comfortable (the less bolted together things there are, the better IMHO). Other than that, it's personal preference
Old Apr 23, 2008 | 10:36 AM
jak5b's Avatar
jak5b
thank for responses.. really help....I think I might be looking with much more confidence now.
Old Apr 24, 2008 | 01:03 PM
Triple8Sol's Avatar
Triple8Sol
H&R and Eibach also make the style with built-in studs. They're better than the KICS ones, because they are hubcentrice, whereas KICS spacers require the purchase of additional hub rings.
Old Apr 24, 2008 | 03:01 PM
DMK's Avatar
DMK
You also have to make sure that the backside of the hub on the wheels has deep enough grooves for the stock studs to stick into. Since 15mm spacers won't cover the stock studs completely.
Old Apr 25, 2008 | 10:31 AM
jak5b's Avatar
jak5b
thanks guys
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
