Tire size 255 rear
Old Apr 22, 2008 | 07:43 PM
12SecRD's Avatar
12SecRD
Default Tire size 255 rear
Just wondering if sticking with the 225/45/18 Front and switching to a 255/40/18 in the rear instead of the 245/45/18 would work ok with traction control, VDC, touring 18" wheels, etc?
Old Apr 23, 2008 | 03:04 PM
The rear tire is 1.50 mm taller than the front. I do not recommend this set-up with VDC.
Old Apr 23, 2008 | 03:11 PM
Bumpinjeep's Avatar
Bumpinjeep
I honestly wouldnt worry about it. You can always turn off the tc if you have too many issues. Im running 255s up front and 305s in the rear and its fine. Sure there are some issues with the TC but its totally livable. I only notice it once a couple of weeks if that.
Old Apr 23, 2008 | 05:47 PM
12SecRD's Avatar
12SecRD
The oem rears 245/45/18 are Overall Diameter:26.68 in even taller then the 255/40's....so thats even taller again...not sure if I am following your theory
Old Apr 23, 2008 | 07:16 PM
antennahead's Avatar
antennahead
I ran the numbers once, and I think 255/45/18 is within tolerance. Could be wrong though.
John
Old Apr 24, 2008 | 06:04 AM
For a complete explanation see: https://my350z.com/forum/wheels-and-tires/203755-will-these-tires-work-with-my-vdc-enabled-car-read-here.html
Old Apr 24, 2008 | 06:08 AM
Sbz33's Avatar
Sbz33
I'm Running that setup 225/45/18f and 255/40/18r and I have no problems.
Old Apr 24, 2008 | 06:23 AM
My350P's Avatar
My350P
I have 225/45/18f and 255/45/18r, no problems at all.
Old Apr 24, 2008 | 08:52 AM
Mike M's Avatar
Mike M
a 255/45 is about +1% from 245/45 would be fine to use, speedo will be slightly off but not much at all, less than 1mph.
Old Apr 24, 2008 | 09:02 AM
noodleman's Avatar
noodleman
do you have vdc?
Old Apr 24, 2008 | 10:17 AM
My350P's Avatar
My350P
Originally Posted by noodleman
do you have vdc?
TCS, but it has the same 3% difference limitation.
Old Apr 24, 2008 | 02:28 PM
Lawn Dart's Avatar
Lawn Dart
I'm running 245/40R18 front and 255/40R18 rear.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
samansharif
Sep 25, 2015 12:31 PM
