tire size
Old Apr 29, 2008 | 03:11 PM
raymondcleung's Avatar
raymondcleung
Default tire size
Is it perfectly fit to put 275/35/19 for 265/35/19???
Will it rub???
thanks
Old Apr 29, 2008 | 05:08 PM
Spike100's Avatar
Spike100
Will it rub???
thanks
I assume you have 265/35-19” and want to replace these tires with 275/35-19”, and wonder if the larger size will rub?
If I understand your question (and you do not have some wheels with a crazy offset) the answer is: Yes you can replace the 265’s with 275’s and expect a good result (no rubbing).
--Spike
Old Apr 29, 2008 | 05:37 PM
raymondcleung
Yes, that was my question.
and i actually have the stock Track wheels.
I don't know the offset.
but will a larger tire fit on the wheel w/o rub?
--Spike
Old Apr 29, 2008 | 07:29 PM
Spike100's Avatar
Spike100
A 275 tire requires at least am 9" wide wheel. If you want to go 285mm wide, you should have at least a 9.5" wide wheel.
You can run either of these sizes without rubbing as long as you have the wheels with the appropriate offset.
--Spike
Old Apr 29, 2008 | 07:56 PM
raymondcleung
I just search on Nissan website and find out the offset of the GT wheel offset is:
18" x 9.0" (front) and 19" x 10.0" (rear) super-lightweight 5-spoke forged alloy wheels by RAYS®
I also used to tire calculator to find out that's 1% difference between 275/35/19 and 265/35/19
So, Is 245/40/18 for 18"x9.0" (front) and 275/35/19 for 19"x10.0" (rear) a good fit???
How do i find out the offset?
mine is just OEM GT Track 18" and 19"
--Spike
Old Apr 29, 2008 | 08:18 PM
Spike100's Avatar
Spike100
18/19-inch Track and GT wheels V2
Front
Offset: +30mm
Weight: 21 lbs 4 oz
Rear
Offset: +30mm
Weight: 29 lbs 8 oz
--Spike
Old Apr 29, 2008 | 08:20 PM
raymondcleung
Front
Offset: +30mm
Weight: 21 lbs 4 oz
Rear
Offset: +30mm
Weight: 29 lbs 8 oz
--Spike
Old Apr 29, 2008 | 08:41 PM
Spike100's Avatar
Spike100
Those sizes will fit. In fact, they are the minimal sizes on these wheels.
+30 offset on these wheels and the wheel width will easily accommodate a larger width tire. For example, you could go 265/40-18” front, and 285/35-19” rear.
--Spike
________________________________
Edit: Although you can fit really wide tires on these wheels, notice that the V2 Track Model wheel/tire setup is very heavy. I think a 30 lb. wheel with a large tire approaches an un-sprung weight that might begin adversely affecting handling characteristics.
Last edited by Spike100; Apr 29, 2008 at 08:56 PM. Reason: To mention the increased wheel weight
Old Apr 29, 2008 | 08:47 PM
raymondcleung
how about 255/35-18" front and 275/35-19" rear?
what's the difference between 255/35-18" and 255/40-18"?
--Spike
Old Apr 29, 2008 | 09:00 PM
Spike100's Avatar
Spike100
how about 255/35-18" front and 285/35-19" rear?
255/35-18" is too short on the front. A better size for the front is 255/40-18".
285/35-19" is perfect for the rear.
--Spike
Old Apr 29, 2008 | 09:09 PM
raymondcleung
Haha...I am kinda confused.
My original are 245/40WR18 (front) and 265/35WR19 (rear) with 18" x 9.0" (front) and 19" x 10.0" (rear) super-lightweight 5-spoke forged alloy wheels by RAYS®, WHAT SHOULD BE THE BEST MATCH with size only available on:
215/35 ZR 18 84 Y XL
255/35 ZR 18 94 Y XL
265/35 ZR 18 97 Y XL
275/35 ZR 18 99 Y XL
295/35 ZR 18 103 Y XL
225/40 ZR 18 92 Y XL
235/40 ZR 18 95 Y XL
245/40 ZR 18 97 Y XL
255/40 ZR 18 99 Y XL
225/45 ZR 18 95 Y XL
235/45 ZR 18 98 Y XL
245/45 ZR 18 96 Y
245/45 ZR 18 100 Y XL
265/30 ZR 19 93 Y XL
275/30 ZR 19 96 Y XL
295/30 ZR 19 100 Y XL
225/35 ZR 19 88 Y XL
235/35 ZR 19 91 Y XL
245/35 ZR 19 93 Y XL
255/35 ZR 19 96 Y XL
275/35 ZR 19 100 Y XL
225/40 ZR 19 93 Y XL
245/40 ZR 19 98 Y XL
255/40 ZR 19 100 Y XL
Thanks...I'm new on changing tires... =)
--Spike
usmanasif's Avatar
usmanasif
I have the same wheels as you. I have 255/285 F/R. OEM tire wall heights. No issues. Even with a 0.8" drop, I don't expect any issues.
Old Apr 29, 2008 | 09:33 PM
Spike100's Avatar
Spike100
245/45 ZR 18 96 Y
On the tire specification chart you posted (and with your wheels), here are your best picks:
Front: 255/40 ZR 18 99 Y XL ...or...275/35 ZR 18 99 Y XL
Rear: 275/35 ZR 19 100 Y XL ... or... 295/30 ZR 19 100 Y XL
--Spike
Old Apr 29, 2008 | 09:40 PM
raymondcleung
Do you mean
255/40 ZR 18 99 Y XL (Front) with 275/35 ZR 19 100 Y XL (Rear)
...or...
275/35 ZR 18 99 Y XL (Front) with 295/30 ZR 19 100 Y XL (Rear)
and...How do i pick between those 2 choices? What are the pros and cons?
Since I changed the tire sizes, will it affect VDC?
--Spike
Old Apr 29, 2008 | 10:22 PM
Spike100's Avatar
Spike100
Do you mean
...or...
Yes… the front/rear configurations you list in your post. Keeping similar sizes front and rear gives more neutral steer and the rears won’t overpower the fronts. Any of these combinations will work.
275/35 ZR 18 99 Y XL XL (Front) with 295/30 ZR 19 100 Y XL (Rear)
275/35 ZR 18 99 Y XL XL (Front) with 275/35 ZR 19 100 Y XL (Rear)
255/40 ZR 18 99 Y XL (Front) with 295/30 ZR 19 100 Y XL (Rear)
About Tire Width:
  • The greater the width difference front to rear, the more understeer. Understeer is not necessarily a bad thing. In fact most cars have some amount of understeer since this is a safer setup for most drivers.
  • When you go past 255 width in front, you may experience “bump-steer” and possibly wandering a little at highway speed.
About VDC: You are changing the tires’ widths, but not the overall diameter. Since you are maintaining the overall diameter, you won’t have a problem with VDC or TCS.
--Spike
