Wheel Size Check
Old May 3, 2008 | 03:36 PM
mcarther101's Avatar
mcarther101
Default Wheel Size Check
Will these wheels work flush with the 2003 350z Track? What tire size would you recommend for the front/back?
Front: 19x9 Offset 18 5x114.3
Rear: 19x10 Offset 22 5x114.3
Old May 3, 2008 | 03:45 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Front: 19x9 Offset 18 5x114.3 - 255 mm tire
Rear: 19x10 Offset 22 5x114.3 - 285 mm tire
Old May 3, 2008 | 04:46 PM
Kinraze's Avatar
Kinraze
my wheels are 19x9.5 +17 on front and 19x10.5 +24 rear. My rear sits flush, and the fronts are sticking out just a little, maybe 1/8th of an inch. I have 275/35/19 on the rear and 255/35/19 on the front. A 245 front tire would probably be right at flush, but it looked too stretched for me on a 9.5 rim. The wheels and offsets you mentioned should be close to flush with a 245/35/19 front and 275/35/19 rear.
Old May 3, 2008 | 04:57 PM
r_seng's Avatar
r_seng
the usual 245/35 275/35 will be fine.
Old May 4, 2008 | 06:42 AM
Zivman's Avatar
Zivman
perfect sizing IMHO.. no worries about fender cutting/rolling/rubbing and still look aggressive.
I would choose a 265/30 front and 295/30 rear. If that is too much for you, go with a 255 and 285 setup
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
samansharif
Sep 25, 2015 12:31 PM
