question and opinions on this size....
Old May 3, 2008 | 06:53 PM
BluBls350z's Avatar
BluBls350z
Thumbs up question and opinions on this size....
Size : 18 x 8.5(front) & 18 x 9.5(rear)
Offset : 32mm(front) & 35mm(rear)
i have a 04 performance (w/ vdc)... hows that offset? to high? what kind of tire sizes should i consider... i was thinkin 245/40 and 275/45? should i run a 20mm spacer in the front and 25 in the rear? any help will be greatly appreciated
thanks
Old May 3, 2008 | 06:57 PM
drivenCSZ's Avatar
drivenCSZ
offsets high...maybe 10mm Fr and 10 or 15mm rear for the spacers
tires...245/40 fr and 275/40 rears.
somebody correct if im wrong
Old May 3, 2008 | 07:09 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old May 3, 2008 | 08:24 PM
BluBls350z's Avatar
BluBls350z
yeah i tried that earlier tonight and i just couldn't figure it out... im tire retarded.... i have no idea about anything about offsets... it just doesn't make sense to me... the lower the number the further out it sticks out? you'd think its the other way around...
does anybody know the stock offset and sized for the 04 performance Z 18"s?
any other opinions? I NEED HELP!!
Old May 3, 2008 | 09:16 PM
http://www.350zmotoring.com/forums/Wheels_and_Tire.php
Old May 3, 2008 | 09:18 PM
Armando's Avatar
Armando
19's
Old May 4, 2008 | 05:13 AM
BluBls350z's Avatar
BluBls350z
awesome... that answered alot of questions...
now for your opinions on tire sizes... 245/40 and 275/45... will that keep my diameter within the allowed size for the VDC not to act up? or should i run 245/40 and 275/40 as stated above?
Old May 4, 2008 | 07:05 AM
The wheels are the same as the NISMO wheels. Recommended tires are here: http://www.courtesyparts.com/Merchan...ode=4030S-18SR
Old May 4, 2008 | 12:33 PM
BluBls350z's Avatar
BluBls350z
so 245/40 and 275/40 it is....
thanks for all your help man
issyz
Jul 2, 2017 03:04 PM
wanderingstuden
Jan 28, 2016 07:03 PM
samansharif
Sep 25, 2015 12:31 PM
