what is a "reasonable" amount of negative camber?
Old May 10, 2008 | 09:06 AM
reserved's Avatar
reserved
Default what is a "reasonable" amount of negative camber?
Hope you guys can help me out a little.....and it isn't even a Z related issue (sorry!)
Just replaced my Toyos with Goodyear Eagle F1's on my CLK 500 and now the rears are rubbing.
Got the fenders rolled yesterday and it didn't help (the fenders are already factory rolled, so there wasn't much to work with)
Anyway, my current rear camber is -1.45 with a recommended "target" of 1.18 (+/-0.3).
My question is, what would be a "reasonable" camber to try to eliminate the rubbing but not eat up the tire. I'm thinking -2.5. Any thoughts from you tire gurus out there would be greatly appreciated.
Old May 10, 2008 | 10:12 AM
Selski12's Avatar
Selski12
I had 285/35/19 on my 10.5" +17 offset rear wheels with a -2.5 camber and it wore out my rear tires in about 9000 miles. So, I don't know if you can use that as a reference given different cars, driving styles, conditions, etc...
Old May 10, 2008 | 10:44 AM
saberphx's Avatar
saberphx
^^ Did you switch your rear tires when wear became uneven, though?
Old May 10, 2008 | 11:34 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
rather than trying to correct it with more camber (which then throws toe out of spec too), I'd recommend visiting a body shop in the area and have the rears pulled slightly
350Z_Al
Oct 29, 2020 07:44 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
