GRRRR - wrong tire size on my stocks?
Old May 19, 2008 | 12:32 PM
jcandas's Avatar
jcandas
Default GRRRR - wrong tire size on my stocks?
OK, I just put on some 245/40f 275/40r for my stock 18" GTR wheels. I didn't just pick this from thin air, as I searched the forum and had a few people said that they ran this setup and it was fine.
Of course, after I put the tires on, I learned that this setup was a +3.7% change on the rear tires and that it might affect VDC.
The other thing I noticed is that the tire is bulging a bit on the rears. So I think the wheels might be a bit too small for these sizes.
So my question is this, besides ordering an entire new set of tires, what are my options?
I was looking at some replacement wheels for the stocks, but if the 275/40 tires are really going to intefere with the VDC, then I don't want to keep them.
Any help would be greatly appreciated...
Old May 19, 2008 | 12:34 PM
iStan's Avatar
iStan
ZR
What are you talking about?
245/40/18 275/40/18 is optimal.
225/45 to 245/40 is 1% change
245/45 to 275/40 is .08% change.
275 on Stocks?? That is not very good..
Old May 19, 2008 | 01:02 PM
jcandas's Avatar
jcandas
^^ you are absolutely right, I retried the calculator and realized I had compared 245/40 r18 to 275/40 r18 instead of 245/45 to 275/40.
Thanks for the slap in the head.
I am still curious about the stock wheels being wide enough for this size (8 & 8.5) for 245/40 r18 and 275/40 r18 as it seems that they bulge a bit on the sidewalls. Could this be from lack of air pressure? I currently have them at 35 PSI, should I run them with a bit more pressure (I do drive rather fast on the "track" usually around 90-95mph) and do some agressive cornering as well.
Again, thanks for the help...
Old May 19, 2008 | 01:19 PM
redlude97's Avatar
redlude97
It bulges because you are trying to install a tire that has a ~10.8" width onto a wheel that is only 8.5" wide. That means the tire has to bulge ~1" on each side of the wheel to fit
Old May 19, 2008 | 01:22 PM
iStan's Avatar
iStan
ZR
^Yup. I run a 275 on a 9" and 10".
Old May 19, 2008 | 01:35 PM
black04ninjaZ's Avatar
black04ninjaZ
Yea buddy, I think you might have misunderstood why people were running 275's in the rear. I run 245's on my 8.5s and 275s on my 9.5s. That tire's way too wide for such a "not wide?" wheel. I think your only option would be to purchase 2 new rear tires
Old May 19, 2008 | 01:46 PM
I would not put a 275 mm tire on a 8.5 inch wheel. Maybe you should forget “upsizing” and stick with the OEM sizes.
Old May 19, 2008 | 07:52 PM
z-u-later's Avatar
z-u-later
You'll be fine with the 275/40s on the 18x8.5 rear rims. Heck, I've mounted 275/40s on stock 17x8 rims on all four corners for autocross without issues.
Old May 19, 2008 | 10:05 PM
jcandas's Avatar
jcandas
They seem to be holding up fine as I did a speed test with them today.
I will put some corner work in this weekend and see how they handle. I think i have convinced my wife that we need a wheel upgrade : ) so I will be looking for a larger size wheel to fit my tires now.
Old May 20, 2008 | 01:22 AM
terrasmak's Avatar
I'll bet the tires you use for that have one hell of a lot stiffer sidewall. Not to mention autocross doesnt involve cornering at higher speeds.
Old May 20, 2008 | 04:53 AM
z-u-later's Avatar
z-u-later
The tires are Hankook Z211s and they are road course tires. I used these instead of softer compounds for autocross since they last longer. The sidewalls are very stiff, and as much as people make a big deal out of it, mounting 275/40s on 8" wide rims is not an issue. I've actually driven my setup on the road and have taken high speed corners without issues.
EnjukuRacing
Misc.
Sep 23, 2015 07:27 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
EnjukuRacing
Sep 11, 2015 08:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
EnjukuRacing
Sep 9, 2015 06:42 AM
