Lug Nutz fell off on Highway
Old May 22, 2008 | 03:16 PM
Zridder19's Avatar
Zridder19
This is why we torque them to spec.
Old May 22, 2008 | 04:35 PM
DavesZ#3's Avatar
DavesZ#3
^^^ Torquing them to spec means nothing if they aren't the correct nut for the stud, i.e. wrong thread pitch.
Old May 22, 2008 | 05:28 PM
Spike100's Avatar
Spike100
Not sure if anyone has mentioned this, but…
The only way to get a true torque value on all lugs is tightening the lugs with the wheels suspended (as is done in the shop).
If you tighten your lugs while the wheels are weighted, you will need to roll the car forward slightly (doing a full 360 rotation during the process) and alternately check each lug for proper torque. That is simply because a weighted wheel may not be flush with the hub, and you won’t get accurate torque values. And, you must do this again after a short drive when tightening the lugs on weighted wheels.
--Spike
Old May 23, 2008 | 09:56 AM
RedBullRR's Avatar
RedBullRR
Originally Posted by DavesZ#3
That right there makes me think that they were the wrong pitch. As with the RX-7 failure, you can get the 1.5 pitch to go on our 1.25 studs and they will tighten but because the threads aren't fully engaged, there's space for the broken/stripped thread material to collect, hence the buildup of debris. Lack of proper engagement means that the threads can and will eventually fail and the nut will pop off.
Thanks for the feedback. I def think there not long enough or just not the rite fit. I contacted a sponsor here for some muteki in chrome, but he hasnt gotten back to me. Wonder if Adam at Z1 has any.
Old May 23, 2008 | 11:36 AM
GalvatronType_R's Avatar
GalvatronType_R
My deeznuts feel off on the highway once.
Dymsi
Sep 29, 2015 11:32 AM
