Lug Nutz fell off on Highway
Old May 22, 2008 | 04:13 AM
RedBullRR's Avatar
RedBullRR
Default Lug Nutz fell off on Highway
Well, I went the cheap route and got Tuner Lug Nuts, I was driving and suddenly I hear a noise I pull over. I notice I'm missing 3 of 5 on the passenger rear, and all five are loose on the driver side rear. Man am I glad I caught that noise before I hit warp speed.
So Tuner Lug Nuts from Auto Zone = Fail! When I took them off they were all rusty (Bought them chrome) with tons of debris coming out from the inside.
So with that said, I am in need of new lugs, but am skeptical on what to buy. Reason is I have bought more then just one set of Lugs, and its either the key doesn't fit in the whole or the Tool doesn't. I bought a set of locks from a member here OEM Nissan, and that didn't work.
So anyone interested in a set of OEM Nissan Locks, let me know 30 bucks shipped were in the US.
Old May 22, 2008 | 04:40 AM
Z04's Avatar
Z04
sorry this happened, but this is a prime example of the phrase "you get what you pay for". check out the rays lugs. a bit pricey but i have had mine on for close to 4 years and no problems at all. those do need an adapter for them to be used with the OEM lug wrench but i think the lug set comes with that as well. BTW, what wheels do you got?
Old May 22, 2008 | 04:45 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
i like my rays lug nuts, i like...not i love. lol
Old May 22, 2008 | 05:24 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I don't see how the lugs would have been the problem. Sounds to me like it wasn't TORQUED down properly.
Old May 22, 2008 | 05:35 AM
RedBullRR's Avatar
RedBullRR
That's what I thought, but i have tightened them more then once. I am kind of a brut and tend to snap the studs if I apply to much pressure. I think they get loose with vibration. I did have some fun with the car the day before.
When I took them off, they were all rusty inside looking like ****, with a ton of debri in them.
Old May 22, 2008 | 05:52 AM
UMW350Z's Avatar
UMW350Z
are they open end lug nuts?
Old May 22, 2008 | 06:00 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I have had open ends from Discount tire and they rusted on the inside as well, but the lugs never came loose. You need a TORQUE wrench and Torque then down to 85-90lb of tq.
Old May 22, 2008 | 06:02 AM
wayneside's Avatar
wayneside
yeah...definitely torque them down correctly!
that could have been a bad situation...
Old May 22, 2008 | 06:04 AM
RedBullRR's Avatar
RedBullRR
Close Ended Lugz - They are spline drive nut's
Next time I go to a tire shop to have them torque it down the rite way. I tend to brake the Studs. Still want to get new ones not trusting these autozone specials.
Old May 22, 2008 | 06:43 AM
BeejZ's Avatar
BeejZ
Doesnt sound like the lug nuts fault. Buy a torque wrench.
Old May 22, 2008 | 07:37 AM
Does not pass sniff test. Faulty lug nuts or operator error?
Old May 22, 2008 | 07:41 AM
DaytonaRoadster's Avatar
DaytonaRoadster
had someone who those damn cheap lugs, i dunno what he did wrong (torque fail?) but i can off, smashed through my windshield and impalied itself in the passanger seat...glad i wasnt carrying anyone
Old May 22, 2008 | 08:21 AM
RedBullRR's Avatar
RedBullRR
Possibly a user error, but I can ensure I tighten them. It just seems they rusted out inside, they just dont hold up.
Old May 22, 2008 | 01:19 PM
tware's Avatar
tware
if you are *sure* you had them at spec torque, which honestly, 90 isnt *that* much, you need to inspect your rotors and studs. Make sure you didnt put 1.50 pitch lugs on there, classic and costly mistake. they will seemingly tighten, and will fly off later spectacularly.
Then, make sure that something is not obstructing your rotor from sitting perfectly on your hub (requires removing caliper). Make sure all your mating surfaces are completely clean (no paint chips or thick rust).
Assuming you did get them tight (not all that hard to do) and they were the right thread pitch, I think your problem was caused by something else.
Old May 22, 2008 | 01:21 PM
chromesilver6's Avatar
chromesilver6
As far as the rust goes always rub a little bit of anti-seeze on your lug studs before installing lug nuts. Then torque to 85ft lbs and then recheck everything after about 200 miles. Good luck!!
Old May 22, 2008 | 01:23 PM
tware's Avatar
tware
btw, wrong thread pitch lugnuts at work
http://www.youtube.com/watch?v=kyMDNzhfwn0
try not to laugh too hard.
Old May 22, 2008 | 02:10 PM
CSF's Avatar
CSF
lol...i remember that one
sucks to be that guy
Old May 22, 2008 | 02:59 PM
DavesZ#3's Avatar
DavesZ#3
Yeah, that was the first thing I thought of when I read the original post.
Old May 22, 2008 | 03:05 PM
Julian@MRC's Avatar
Julian@MRC
No sounds like the incorrect thread pattern to me..Ever see that vid of the RX7 at an autocross, he bought the wrong lugs and all 4 wheels fell off..
Old May 22, 2008 | 03:16 PM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by RedBullRR
....When I took them off they were all rusty (Bought them chrome) with tons of debris coming out from the inside..
That right there makes me think that they were the wrong pitch. As with the RX-7 failure, you can get the 1.5 pitch to go on our 1.25 studs and they will tighten but because the threads aren't fully engaged, there's space for the broken/stripped thread material to collect, hence the buildup of debris. Lack of proper engagement means that the threads can and will eventually fail and the nut will pop off.
