Work KAI or Enkie RPF1
Old May 23, 2008 | 02:39 PM
vanos954's Avatar
vanos954
Both look good to me. I'd get whatever looks best to you and then mount some track rubber on your stock wheels and auto-x on those. Auto-x on baller wheels will only mess them up from the constant mounting/dismounting of rubber.
Old May 23, 2008 | 03:30 PM
Nevaland90's Avatar
Nevaland90
Originally Posted by first350
it's really hard to beat the performance of the RPF1's...there's not really any other wheel within the same price range at the same weight.
*IMO, 275 all around is a lot more fun! (but I tend to like wide tires )
***if you get the works, don't do staggered. the 18X8.5+20(ish) does not have the same concave look. I went 18X9.5 +20 and IMO it's perfect.
no way, thats the vagina size...18x9.5 +12 all around is perfect. even that size could use a spacer.
Old May 23, 2008 | 05:59 PM
yusoslo's Avatar
yusoslo
^^^that car is why I sold my RX-7 for a 350Z...100% serious too. I love the look, no body kit...keeps the lines, nice and low...and flush.
Oh and I would be doing +12 all around.
I have a touring model so I dont think I can run 255/35/18 all around because of VDC.....but what do I know??
Old May 23, 2008 | 06:11 PM
bluesi808's Avatar
bluesi808
go with the works and get an aggressive offsett. i like the concave look. can't get more jdm than works.
Old May 23, 2008 | 06:55 PM
Lawy'dU's Avatar
Lawy'dU
Originally Posted by Brick-Z
Enkei in black
+10000
Old May 23, 2008 | 07:18 PM
DallasZ's Avatar
DallasZ
So what's the perfect combination of R888 tires for the Enkei 9.5 front and 10.5 rear combo?
Old May 23, 2008 | 07:22 PM
first350's Avatar
first350
Did you have to roll your fenders to clear that? It looks like you're running a 245ish in the rear...so you probably didn't. But if you're running something wider, then a +12 offset w/ -2 camber may rub.
*I was running:
18X9.5 +20/22 (forget which) w/ 275/35/18, -2 camber, dropped 2.5"...I had less than 10mm clearance from the un-modified fender.
Rev_Night
Nov 7, 2020 06:00 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
_bit
Oct 2, 2015 07:49 AM
