245/45r17
It will fit, but if you use the tire calculator that size is actually smaller in diameter than the front. If I were you I would get a 255/45, the diameter is near identical with it being slightly larger than the front. You may experience bad handling performance with that size you listed for the rear. Also if you're VDC equipped it may throw that off too.
http://www.miata.net/garage/tirecalc.html - Using this calculator helps too.
Originally Posted by Zman636
It will fit, but if you use the tire calculator that size is actually smaller in diameter than the front. If I were you I would get a 255/40, the diameter is near identical with it being slightly larger than the front. You may experience bad handling performance with that size you listed for the rear. Also if you're VDC equipped it may throw that off too.
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
235/50-17 4.6in 13.1in 26.3in 82.5in 768 0.0%
255/40-17 4.0in 12.5in 25.0in 78.6in 806 -4.6%
245/45-17 4.3in 12.8in 25.7in 80.7in 785 -2.2%
Originally Posted by jehamilton_98
So will the 255/40 fit the stock 17" wheel? And you say the diameter is near identical?
Originally Posted by theaxe1149
try 285/40-17 for rear
as for those sizes, the sidewall heights say it will work but the max width wheel you can safely stick onto a 17 x 7.5 wheel is 235, and for the rear 17 x 8.0 is the same. anything over those widths and you will have overhang and uneven wheel wear causing you to have to replace tires more frequently and have a very crappy ride best bet if you want wider tires is to get the proper sized wheels then get the right sized tires.
Originally Posted by davidv
You are welcome.
How do you know that I havent said "Thanks" in a PM to someone?
If you really need a "Thanks" give me some worthy information that will actually help me make a decision as to what type of tires I could put on the rears that would be both affordable and safe.
"Thanks" in advance...
I should have said "thank you" for what? Your chiming in with "The front tires are taller than the rears."
Well I have 235/45/17 front and 245/45/17 rear with no problems at all. I don't have VCD though but the rear is still larger O.D. than the front. Handling is much better too.
Laurenx3
Mid-Atlantic Marketplace
Mar 13, 2012 05:20 PM
