Con's of getting 245 in front and rear
Old Jun 16, 2008 | 04:39 PM
Spike100's Avatar
Spike100
Originally Posted by Tubbs
I have a square 245 setup. Works great.
But... Didn't you report a problem with VDC and your setup?
--Spike
Old Jun 17, 2008 | 08:21 AM
Tubbs's Avatar
Tubbs
--Spike
Certainly, but it was my fault for not turning VDC off.
Old Jun 17, 2008 | 09:57 AM
Concave's Avatar
Concave
^^ Are you running the same overall diameter on fronts and rears?
--Spike
Yes but I do not have this VDC you guys are talking about, sorry.
im running 245/40/18
Old Jun 17, 2008 | 11:13 AM
Bumpinjeep's Avatar
Bumpinjeep
Why 245? Go with something wider.
Old Jun 17, 2008 | 11:31 AM
Tubbs's Avatar
Tubbs
Lighter, cheaper, better in wet, and no need to go wider unless you have more power?
Old Jun 17, 2008 | 01:16 PM
Concave's Avatar
Concave
Yea. my 245s are just fine.
hopefully the guy has something to push his 305's or else he could be running slower trying to turn all of that rubber.
Old Jun 17, 2008 | 01:19 PM
Me350Z's Avatar
Me350Z
I have also been considering this. For economical purposes I think people want a squared setup so they can rotate their tires and get the longest use out of them. For those who are true enthusiast they would more than likely go with staggered set-up.
Since times are tough, anyone know the overall diameter for stock 17" 2005 tires? Would I be able to run a square setup on 235/50/17 without affecting the TCS?? Fronts are 225/50/17.
Ok… getting back to the Op’s original question:
If you want to rotate tires and you have stock 18” wheels (8” front and rear, or 8” front and 8.5” rear), here are the considerations:
  • The 350Z has a staggered tire-height (i.e., the fronts have an overall diameter of 25.9” and the rears have an overall diameter 26.7"). If you mount tires that have overall diameters different from the stock sizes, your speedometer will be inaccurate, and VDC or TCS might malfunction (if your car is equipped with these features). In other words: If your car has VDC or TCS, do not mount tires that have the same overall diameter (front and rear) since doing this can result in erratic deployment of VDC/TCS.
  • If you do choose to go with a square setup (same tire width and same tire overall diameter) on 18” wheels that are 8” to 8.5” wide, go with 245/40-18” or 245/45-18” all around. 245’s fit 8” to 8.5” wheels, and 245/40 provides better acceleration while 245/45 looks better. Of course if your car is equipped with VDC, either of these arrangements will result in problems and unsafe operation of your car.
My thought here is that Nissan never intended that you should rotate your tires on the 350Z (front to rear), and designed the car to run with a staggered tire-setup (height and width). So I would advice not doing this. In fact I believe that was terrasmak’s point (maybe a little sarcastic, but probably for emphasis).
And... I would never run all-square on my 350Z just to accomplish longer use of tires.
--Spike
Old Jun 17, 2008 | 01:42 PM
redlude97's Avatar
redlude97
You can't rotate those anyways becase the rear wheels are 8" while the fronts are only 7.5"
Old Jun 17, 2008 | 01:56 PM
Me350Z's Avatar
Me350Z
Okay, good point.
Forget about the rotation, can I put the 235/50/17 on the front wheels since they still have tread, then just buy new rear tires. What happens if the tires are slightly bigger that than the wheels?? Affect TCS?
Old Jun 17, 2008 | 02:32 PM
pony_killer's Avatar
pony_killer
Arada ninda apa
i too also wanted to go non-staggered but after a little research, i too figured that nissan wanted the car, 06+ to be staggered..therefore i went with the Toyo T1R 225/45/18 front & 245/45/18 rear. As much as I know that I'll be lucky to even get 20k out of them, I figure spending a little right now would better then spending a lot later to get my TCS fixed due to inaccuarate tire sizes.
Old Jun 17, 2008 | 03:22 PM
Spike100's Avatar
Spike100
You can put 235/50-17" all around on your car and expect TCS to work just fine. This setup will also work even with VDC.
I run 225/55-17" all around for my winter tires/wheels, and have no problem with VDC/TCS.
--Spike
Okay, good point.
Old Jun 17, 2008 | 04:18 PM
Concave's Avatar
Concave
to play with diameter size's check out this website:
http://www.miata.net/garage/tirecalc.html
Old Jun 17, 2008 | 10:57 PM
Tubbs's Avatar
Tubbs
uhh... why? For going in a straight line?
Old Jun 18, 2008 | 04:24 PM
Spike100's Avatar
Spike100
--Spike
If I remember correctly, your all-square setup is 245/40-18” tires all around on 18x8” wheels. You reported an incident when VDC activated unexpectedly while driving “on the street.” The thread became lengthy, and some people suggested that the overall tire diameter may have been an issue.
I notice that tire-size-calculators give a pass when going from 225/45-18” (the stock size on the 350z’s front tires) to either 245/40-18” or 245/45-18” on the front.
However, tire-size-calculators warn against swapping 245/40-18” for 245/45-18” (the stock size on the 350z’s rears) on the rear.
So… I wonder if an all-square setup should be 245/45-18” all-around instead of 245/40-18” for cars equipped with VDC/TCS. I’ve never tested this setup (I’m running 245/40-18” front and 245/45-18” rear, which works flawlessly with VDC/TCS).
It would be useful to have an all-square setup where you didn’t need to turn VDC off every time you start the car. I’m interested in your comments or comments from anyone who has run this setup (245/45-18" all-square).
--Spike
Old Jun 18, 2008 | 05:10 PM
Tubbs's Avatar
Tubbs
--Spike
No, I have 9 inch rims with the 245/40/18's all around. I was doing some hardish canyon driving, and the vdc got wonky. and scared the **** out of me. I make sure to turn vdc off in any road trips now. No problems after.
Old Jun 18, 2008 | 05:36 PM
Spike100's Avatar
Spike100
Would 18x9” (vs. 18x8”) wheels result in a lower profile (and thus less overall diameter) using 245/40-18” tires?
I don’t know, but a definitive answer would certainly be interesting and useful. I would think that 245’s on a 9” wide wheel will be a stretched at least a little.
I think I now understand why your setup does not work with VDC. Your failure with VDC provides a good clue for the correct wheels and tires arrangement in an all-square setup for a reliable solution with VDC.
--Spike
Old Jun 19, 2008 | 05:02 AM
terrasmak's Avatar
Yes it will, but not much.
Old Jun 19, 2008 | 05:55 PM
  #38
Spike100's Avatar
Spike100
^^ With that in mind, and in Tubbs case, he might want to try 245/45-18" all-square. That tire size remains within tolerance for VDC and overall tire diameter, front and rear.
--Spike
Old Jul 24, 2008 | 11:09 AM
  #39
rzua5's Avatar
rzua5
I am running 275/30/19F and 275/35/19R...its not a squared set up and i try to keep a stagger in diameter to make my vdc happy. It give the car a much much neutral feeling. I've gone through a number of fitment before and by far Non-stagger width tires are the best imo.
Old Jul 24, 2008 | 02:31 PM
  #40
terrasmak's Avatar
Originally Posted by Concave
<- non staggered and the Z handles like a dream. I find it much better than a staggered set up.
dont listen to what any e-thug tells you on an internet forum. alot of research goes along way.
some magazine tested both methods and found the Z handled better non staggered. I had staggered, so I wanted to try non staggered.. I loved it.
Yes it does handle better, but thats on a smooth road/track. In the real world or expansion joints, grooved roads etc etc the car gets twitchy with the front and rear having the same height. With that said , if your roads don't have all the stuff mentioned you will be just fine, or get camber arms with castor adjustment for the front.
Obadabot
Jun 18, 2023 11:31 PM
