Problem with wheel spacers...
Old Jun 15, 2008 | 01:58 PM
JonnyRod's Avatar
JonnyRod
Default Problem with wheel spacers...
I purchased a pair of hubcentric wheel spacers for my rears...here's the link:
http://cgi.ebay.com/ebaymotors/ws/eB...057191356&rd=1
Yes its ebay...but i've ordered from this company before. Anyways, for some reason they do not sit flush against the rotor, so they don't torque down properly. I'm worried that it might be the fact that i have aftermarket rotors that is causing that 3mm difference...OR are they just a defective product that didn't get drilled properly? Here are some pics to show what i mean...
Old Jun 15, 2008 | 04:09 PM
JonnyRod's Avatar
JonnyRod
bump...need some help
Old Jun 15, 2008 | 04:11 PM
Not sure of the reason for the space.
Incorrect center bore?
Center bore is machined improperly?
Old Jun 15, 2008 | 05:00 PM
JonnyRod's Avatar
JonnyRod
Thats what i was thinking...but would there be any chance that my aftermarket rotors could be different in size?
Old Jun 15, 2008 | 05:32 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
If it is 3mm all around the spacer then it is probably the reason you stated, and if so don't worry about it that's 3mm more flush goodness
Old Jun 15, 2008 | 05:47 PM
chromesilver6's Avatar
chromesilver6
Just take them to a machine shop and have the bore out the inside on a lathe. Shouldnt cost to much and it will fix the problem.
Old Jun 15, 2008 | 05:48 PM
orangeflash's Avatar
orangeflash
bit off topic, but i ordered some aftermarket drilled rotors and they gave me one rotor that wasnt even finished from the factory, it still needed some grinding from the center... They finally sent me a new one. anyways, this may be the same type of problem, maybe your rotor or spacer was not machined correctly...
Old Jun 15, 2008 | 06:56 PM
Don't think so. The diameter of the hub is still the diameter of the hub.
Old Jun 15, 2008 | 07:44 PM
JonnyRod's Avatar
JonnyRod
The diameter of the hub isnt the problem...check out the pictures again if youre confused
Old Jun 15, 2008 | 08:18 PM
Triple8Sol's Avatar
Triple8Sol
It's def the spacer. People keep trying to convince me that EBay spacers are "just as good." Here's yet another example to prove that they're NOT
Old Jun 15, 2008 | 08:33 PM
moforeynolds's Avatar
moforeynolds
exactly.
Old Jun 15, 2008 | 09:37 PM
terrasmak's Avatar
Send them back and pay the $15 difference for some quailty Ichiba spacers.
Old Jun 16, 2008 | 01:36 AM
cbr900son's Avatar
cbr900son
Have the center machined. If its hitting the hub like u said then just have them take off a very small amount.
Old Jun 16, 2008 | 03:21 AM
Doba's Avatar
Doba
dont send them back.. have them turned on a laithe by a machine shop and youll be good to go within minutes.. minor problem
Old Jun 16, 2008 | 04:36 PM
JonnyRod's Avatar
JonnyRod
yea i think i'm gonna go with that idea...thanks
Old Jun 16, 2008 | 06:00 PM
gothchick's Avatar
gothchick
+1
But next time, stay away from eBay.
Obadabot
Jun 18, 2023 11:31 PM
Uriyo_
Sep 8, 2021 08:46 AM
