Snapped a bolt while removing rims
Old Jun 19, 2008 | 02:43 PM
Z_rican's Avatar
Z_rican
Default Snapped a bolt while removing rims
I was removing the lugs so I can put on my spare tire and I snapped 1 of them. Will I be able to just buy a new bolt or do I have to buy the whole assembly?(I'm not sure what it's called)
Does any one know how much money this will cost? I'm kind of stuck and the Z is my DD. Does anyone have any info to help me out please?
Thanks
Old Jun 19, 2008 | 02:48 PM
SpoilsofWar's Avatar
SpoilsofWar
You can replace just the stud.
Front or rear axle?
Front part number is: 43222-Z33001 $2.22 each
Rear part number is: 43222-Z33002 $2.83 each
Old Jun 19, 2008 | 03:14 PM
TBDesigns's Avatar
TBDesigns
Thanks
Me too I'm rolling with 4 right now still haven't replaced the other and it's been about 4000 miles on just the 4
Old Jun 19, 2008 | 03:32 PM
Z_rican's Avatar
Z_rican
I snapped the rear left. Is it a pain to replace?
Old Jun 19, 2008 | 03:33 PM
Z_rican's Avatar
Z_rican
i was worrid to drive the Z inthat condition, I'm guessin I'll be ok for a few days while I buy the new bolt.
Thanks for the info fellaz.
Old Jun 19, 2008 | 05:55 PM
badkarma85's Avatar
badkarma85
It's not a pain to replace, it's actually quite straight-forward with the proper tools.
Cheap fix
Old Jun 19, 2008 | 06:45 PM
cbr900son's Avatar
cbr900son
U will be suprised how easy it is.
Old Jun 19, 2008 | 06:51 PM
r_seng's Avatar
r_seng
I assume you didn't use a Torque wrench when tightening the lugs, or you used an impact gun and over torqued it.
This always happens to my buddies, they never listen.
Old Jun 19, 2008 | 07:06 PM
Monsta's Avatar
Monsta
Any aftermarkets available or is it really necessary?
Old Jun 20, 2008 | 08:23 AM
Z_rican's Avatar
Z_rican
I bought the car a few months ago. I got a nail in my original tires, but I'm assuming an impact gun was used. Is there a how to on here on how to change the bolts? I can't seem to find any.
Old Jun 20, 2008 | 10:07 AM
bryan@Z1's Avatar
bryan@Z1
Vendor - Former Vendor
Drive what is left of the broken one out with a hammer and punch.
Get an extra lug nut or standard nut that fits the stud, open ended so that the stud can come all the way through it.
Place the stud into the hole and then place a stack of washers on the stud, on the front (wheel) side of the hub.
Screw the open ended nut on to the stud and tighten it down to pull the stud through. An impact wrench is best to do this with. You can do it with a standard lug wrench but you will have to find some way to keep the hub from turning while you tighten it down.
Old Jun 20, 2008 | 12:36 PM
Z_rican's Avatar
Z_rican
I'll try it this weekend.
Old Jun 21, 2008 | 04:09 AM
Z_rican's Avatar
Z_rican
Do I have to remove the brake rotor first ????
Old Jun 21, 2008 | 05:31 AM
j.arnaldo's Avatar
j.arnaldo
H-u-g-e advantage of a five-stud/nut set up! When you've only got four, it's
worrisome--and dangerous--to ride on three!
Old Jun 21, 2008 | 07:12 AM
CSF's Avatar
CSF
not sure about the rear...but i didn't have to remove the front rotor to do this. maybe it's the same for the rear
AbrasiveRaysive
Sep 20, 2021 02:29 PM
ablaine
Nov 29, 2016 10:13 AM
Depravity
Oct 1, 2015 04:49 PM
