offset?
Old Jun 28, 2008 | 10:37 AM
TX-350Z-TX's Avatar
TX-350Z-TX
Question offset?
ok first of all i know the "search" police will probbably blast me on this one, but, here goes..... i am fairly new to the whole modding scene and am no tecnological genius. i want to replace my stock wheels, but with SOO many options it is starting to get confusing. first you choose brand, then style, then size, and finally offset. the first three i got down, it is the offset that i dont quite understand. i hear people talking about "agressive" offset etc.
would some one in "simple" terms explain me this offset thing?
also is i was curious if you could have a set up with 19's in the front, and 20's in the back? basically i want a set of wheels that have a incredibly deep rear lip.
any help would be greatly appreciated. and for the "search" police---go ahead, i expect your comments--hell it is another oppurtunity to boost your post count!
Old Jun 28, 2008 | 11:34 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
More lower offset = stick it out.
Old Jun 28, 2008 | 12:55 PM
Done Deal DR's Avatar
Done Deal DR
^^^thats about as simple as it gets.
I'm not going to go all rent-a-mod on you, but I will tell you that there are many threads where people show their wheels and list their offsets and tire sizes, suspension work, etc, that will tell you exactly what you want. This is an easy way to find what you like and what your choices inherent advantages and disadvantages are.
Old Jun 28, 2008 | 12:59 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Here's the technical definition.
edit: dang wiki strings. Google "What are wheel offsets", then go to wikipedia.
Old Jun 28, 2008 | 05:03 PM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
Old Jun 28, 2008 | 05:07 PM
Yes. You could put 20 inch wheels in front and 17 inch wheels in back if you wanted. Read and learn about matching OEM tire height.
Old Jun 28, 2008 | 08:24 PM
chopperman's Avatar
chopperman
Think of it as this way, the lower the offset the more the wheel is going to be pushed out of the wheel well. The higher the offset the more it is going to be sunk into the wheel well.
Old Jul 3, 2008 | 09:08 AM
You are welcome.
Old Aug 7, 2008 | 12:32 AM
nismo_nate's Avatar
nismo_nate
so will a 35 offset be pushed in? the rim is 18x9.5 +35... just trying to find out before i buy them.. thanks
also will this same setup be okay on all four wheels?
Old Aug 7, 2008 | 02:30 AM
fatboy.yoshi's Avatar
fatboy.yoshi
sounds close to stock...might be ok for your fronts (maybe a lil lower would be good)...but you could go wider in the back...
Old Aug 7, 2008 | 02:49 AM
galant350z's Avatar
galant350z
Please don’t buy them! search picture of other members wheel in wheel/tire section.
Old Aug 7, 2008 | 03:16 AM
genegoesfast's Avatar
genegoesfast
needs to be more like +22 to flush out
Old Aug 7, 2008 | 06:15 AM
fatboy.yoshi
im actually waiting on my wheels to come in...i went 19x9.5 +4 up front and 19x10.5 -15 out back....and next year imma join the 20 in game
Old Aug 7, 2008 | 01:32 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Offset is the distance of the mounting surface of the wheel (the back pad where the wheel meets the hub of the car) to the center line of the wheel. Wheel offset and wheel width go hand in hand.....you can't get any info on how it will look, fit, clear etc without knowing both pieces of info
That being said, 18x9.5 +35 is not going to give a very good look on the car at all (and sounds like a generic, cheesy wheel shop type fitment to me)
seagrasser
Oct 11, 2015 03:27 PM
etong
Sep 10, 2015 06:14 PM
