New Rear Tires Spinning Problem
Old Jul 4, 2008 | 12:26 PM
Looks Fast's Avatar
Looks Fast
Default New Rear Tires Spinning Problem
I got new rims and tires on my 350Z, and now when I take corners at 50-60mph my spinning light comes on and I can feel my rear tires losing control. Any ideas why and how to fix this?
Bridgestone Potenza RE050A (STOCK)
Nissan Stock 2007 Rim
F 225/45R18 91W
R 245/45R18 96W
New wheels I'm running:
Yokohamas with Maya MRS Rims
F 245/35R20 95Y
R 275/30R20 97Y
Old Jul 4, 2008 | 12:48 PM
Kinraze's Avatar
Kinraze
The overall diameter of your front tire is larger than your rear. I am assuming you are running 19 inch rims now. Your front diameter is 25.75in, your rear diameter is 25.49in. Your car is meant to have a larger diameter tire in the rear. You need to put a 35 series tire on rear instead of the 30 you have.
Edit: My bad I see you have 20s, but your front is still larger in diameter, front=26.75, rear=26.49, maybe go with a 30 in the front instead.
Old Jul 4, 2008 | 12:49 PM
a. All new tires are are slippery. Give them 100 miles.
b. What Yokohama tires?
Old Jul 4, 2008 | 01:46 PM
Looks Fast's Avatar
Looks Fast
S drives
Old Jul 4, 2008 | 01:55 PM
DavesZ#3's Avatar
DavesZ#3
The 245/275 combo only works when both front and rear are the same profile (30, 35, 40, 45). If you mix profiles, you risk causing problems with TCS/VDC which is apparently what you're seeing.
Full explanation here.... https://my350z.com/forum/showthread....1&postcount=42
350Z_Al
Oct 29, 2020 07:44 PM
TDPrank
Sep 29, 2015 12:51 PM
TDPrank
Sep 28, 2015 06:29 AM
samansharif
Sep 25, 2015 12:31 PM
