Tire pressure problem/ need an expert
well i read this thread about tire pressure
https://my350z.com/forum/350z/197329...44#post3788619
and according to it you cant clear the tire pressure light.
i'm not going into details but what i need to know is how to clear this light. i know it will come back.
i try unplugging the battery for 1/2 hour which didn;t work. so i'll leave it off all night see what happens
i try the same procedure to clear the check engine light by pressing the gas counting seconds and that didn;t work. though i think i did reset my ecu, but i'm not sure.
does any one know how to clear it, taking out a fuse, with computer, setting it on fire, or beating it with a hammer
thanks
thanks
There is no way to clear the light other than putting the sensors back in the wheels. As long as the TPM system no longer gets the signal, the warning and bulb will illuminate. It's have nothing to do with reseting the ECU, disconnecting the battery, etc. It's doing exactly what it's designed to do.
Sure, you could take the dash apart and remove/disable the bulb but it's probably less effort to reinstall the sensors.
