5mm Spacer for SF-Challenge
Old Aug 5, 2008 | 08:29 AM
350ZPK's Avatar
350ZPK
Default 5mm Spacer for SF-Challenge
First, i will let you know what i have
19x9.5 with 18 offset with the 10mm Project Kic Spacers
19x10.5 with 22 Offset
Is it worth getting the 5mm spacer for the rear?
If so, i know Project Kic dont sell a 5mm spacer, anybody sell them with built in studs?
Thanks
Old Aug 5, 2008 | 08:56 AM
johzp's Avatar
johzp
I dont think 5mm is big enough to include build in studs. So front is +8? if so i would say go with a spacer in the back
Old Aug 5, 2008 | 12:25 PM
350ZPK's Avatar
350ZPK
it was 28 now 18
Old Aug 5, 2008 | 12:26 PM
350ZPK's Avatar
350ZPK
Can i just run the spacer and just use the OEM studs?
Old Aug 5, 2008 | 01:36 PM
Steve-O Z33's Avatar
Steve-O Z33
5mm spacers will work with OEM studs but you will have very little thread holding. Buy some 45mm studs.
Old Aug 5, 2008 | 01:40 PM
terrasmak's Avatar
www.ichibausa.com for a great set of 5mm spacer that include the press in studs needed for the install. The will take about 35 minutes a side to install and are well worth the safety of the longer studs. I would order there fronts too, and get ride of all the extra bolts and hardware that can fail with the Kics junk.
Old Aug 5, 2008 | 01:56 PM
350ZPK's Avatar
350ZPK
Do i have to rip off my oem studs with the ichiba?
Or can they just stay and put those on with the longer studs?
Old Aug 6, 2008 | 04:12 PM
Steve-O Z33
Ichiba makes spacers with built-in studs and spacers that require stud replacement.
If you are asking if you have to cut down your stock 1s to install the spacers with built-in studs, it will depend on how the back of your wheel looks. (Does it have 10 holes or just 5?)
Old Aug 6, 2008 | 05:57 PM
terrasmak's Avatar
Old studs get pulled out and thrown in trash , new studs get pulled in. Its simple and safe. I would ditch the other you have and get a similer set.
The 10mm set you have is basically changing your 10mm steel hub to a 5 to 7mm aluminum hub. I doubt they can take much of a hit.
Old Aug 7, 2008 | 01:37 PM
Triple8Sol's Avatar
Triple8Sol
Swap your 10mm to the rear, and then run 15mm in the front. Seriously.
Old Aug 12, 2008 | 11:04 AM
350ZPK's Avatar
350ZPK
That would be alittle bit to aggressive
Old Aug 12, 2008 | 12:07 PM
z33allme's Avatar
z33allme
10mm all around...
FromGtoZ
Sep 20, 2015 03:41 PM
torchkc
Sep 11, 2015 08:26 PM
