New rims and tires sideways way 2 easy
Old Aug 28, 2008 | 01:57 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
1. your sizes are far too narrow for any meaningful traction
2. check your tire pressure and alignment specs
Old Aug 28, 2008 | 01:59 AM
terrasmak's Avatar
Well everytire i've run a nonstaggered setup (front and rear the same height ) the car does exactly what you say. Bump up to a 245/45 rear if you want to keep the streched look and your problems will magically go away.
Old Aug 28, 2008 | 02:45 AM
Manu's Avatar
Manu
Originally Posted by VQZ33
yea i dunno it doesnt really feel like im sliding around i would say more like it has excessive body roll if that makes any sense. I just really think its weird i dont really know if it's the tires per say, but i dont really know anything about it, it just feels very "touchy feeley" like when i turn the wheel like the whole car just dives in that direction and when i turn it back i feel like its about to loose itself really weird.
Most of that "body roll" is due to the fact that your thread blocks are a lot taller than they were on your old tires, so they bend more. This is why old tires are a lot more responsive than new ones.
You also have the silicone from the moulding process compounding the effect.
Wait 500 miles for the silicone to go away, and you can really lean on the tires. That initial body roll will eventually disappear.
Old Aug 28, 2008 | 03:37 AM
Z04's Avatar
Z04
i guess i will never understand why people whine and cry about handling problems when they do not use the proper sized tires for the wheel size. but hey, it looks good right? looks are more important that proper handling it seems
Old Aug 28, 2008 | 06:39 AM
Concave's Avatar
Concave
here is mr z04 again.... lol...
it shouldnt be tire size since... many of us use the same specs and even push our cars to the limits. My car feels solid and actually can take turns easier than if i had humoungous rear tires. It is much more responsive.
I agree with the other 2, has to be the tires. They must have sidewalls that are too stiff or too soft for your preference? Are you the only one with 245/40/18 all around in your area? if you were close to me... id let you try mine, it feels so good.
Old Aug 28, 2008 | 08:12 AM
There are better tire choices available:
https://my350z.com/forum/wheels-tire...uld-i-get.html
EDIT: You put a 245 mm tire on a 9.5 inch wheel. Please don’t complain. It makes you look silly.
Old Aug 28, 2008 | 08:30 AM
Voboy's Avatar
Voboy
check and see if your tires are mounted correctly. I believe they are 1 directional.
Old Aug 28, 2008 | 01:07 PM
AllstarE4's Avatar
AllstarE4
Sleeps in 350Z
Check your tire pressure all around. Always start with the simplest of things.
Old Aug 29, 2008 | 03:32 AM
terrasmak's Avatar
Read post #22, explains a lot. Well more about it, when you lower just the rear of your car (yes you did with your tire size) you change the front, increasing the castor. By doing this the car become more responsive (twitchy) especially on grooved and uneven streets. Some people have no problems with this, some of us do this setup for the track. I know personally with Vegas roads i would not want to daily drive on a set up like that.
Its not just VCD/TCS that is setup for staggered height, your suspension is too.
Old Aug 29, 2008 | 10:30 AM
VQZ33's Avatar
VQZ33
Read post #22, explains a lot. Well more about it, when you lower just the rear of your car (yes you did with your tire size) you change the front increase the castor. By doing this the car become more responsive (twitchy) especially on grooved and uneven streets. Some people have no problems with this, some of us do this in out setup for the track. I know personally with Vegas roads i would not want to daily drive on a set up like that.
Its not just VCD/TCS that is setup for staggered height, you suspension is too.
What i was figuring was that if i can get some good sway bars i can adjust come of the difference of the suspension setups that stock has. Obviously th car is setup for a staggered setup but i am running a non stagger setup to eliminate the nasty understeer that the car has, so my main question is if i can a good set of sways could I tune it to run this setup better and eliminate this "body roll" feeling? if so how should i set up the sways?
Old Aug 29, 2008 | 11:22 AM
terrasmak's Avatar
You can get front control arms with Caster adjustment or like you said you want a non stagger for understeer reasons, buy 245/45's for the rear. Sways will do nothing for what you indicate.
Old Aug 29, 2008 | 12:48 PM
bbs350z's Avatar
bbs350z
i know new tires always come with a thin coating of protective "gel like material" and fades away after 100 miles or so? this could be an added factor. heard nothing but bad reviews about the 555
Old Aug 29, 2008 | 12:56 PM
black06z's Avatar
black06z
245/40/18 is way too small for that 9.5" width. I know there's that silicone layer on new tires that make it feel "slippery", but, the tire size doesn't help either. You should be up like 265/35 or something. Too Stiff or too soft sidewalls has nothing to do with it.
Old Aug 31, 2008 | 07:41 PM
M3ANMACHINE's Avatar
M3ANMACHINE
Nitto 555 FTL
Rev_Night
Nov 7, 2020 06:00 PM
ablaine
Nov 29, 2016 10:13 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
