maximum width tire on the 07 base wheel?
Old Sep 6, 2008 | 07:36 AM
ryanschram's Avatar
ryanschram
Default maximum width tire on the 07 base wheel?
what is the widest size tire you can run on the 06-08 18" wheels?
Old Sep 6, 2008 | 07:46 AM
singh's Avatar
singh
_______________
Dude just stick to the recommended OEM sizes.
You utilizing a bigger tire than what can fit properly will net you zero performance benefits.
In other words, you slapping on a bulging tire will not get you any advantage, hell I see you at a disadvantage for the added weight. If your car is pretty much stock, then the OEM sizes are absolutely plenty grip. If you say no that is because you cannot drive and do not know how to optimize grip.
Old Sep 6, 2008 | 08:36 AM
ryanschram's Avatar
ryanschram
straight and to the point, thanks.
Old Sep 6, 2008 | 03:37 PM
lowrider's Avatar
lowrider
You have 8" wide fronts and 8.5" rears. You can safely run 245/40/18 in front and 265/40/18 in the rear. I would not go any wider on your stock wheels. Contrary to what has been said, your Z will handle and look better.
Lou
Old Sep 6, 2008 | 03:44 PM
terrasmak's Avatar
Lou
Perfect answer, to bad tire selection is crappy for 265's. Michelin and Federal both make them, not many others.
Another popular setup is stock sized rear with 245/40 front. This improved the handling and does looks better than normal stock sizes.
Old Sep 6, 2008 | 06:23 PM
ryanschram's Avatar
ryanschram
i guess im going to have to wait a while for more responses before i get my new tires.
Old Sep 6, 2008 | 07:17 PM
joe645733's Avatar
joe645733
ill give you a response.
on an 8.5 wheel. go 245/40. or 255/35. its not science. you wont lose any performance but just feel like you put new tires on.
my suggestion, buy new wheels before you start spending money on tires.
bye.
Old Sep 6, 2008 | 07:24 PM
ryanschram's Avatar
ryanschram
bye.
i agree, but i like the stock wheels.
Old Sep 7, 2008 | 07:05 AM
lowrider's Avatar
lowrider
bye.
Use neither of these two sizes on the rear of your "Z" as the outer diameter is too small.
I also like the stock 18" 350z wheel/ IMHO, it's one of the best looking stock wheels out there.
Actually these are the tires available in the 245/265 combo:
http://www.tirerack.com/tires/Compar...r=&RunFlat=All
Lou
Old Sep 7, 2008 | 11:58 AM
Be patient. You will get any answer that you want.
Old Sep 8, 2008 | 08:47 AM
redlude97's Avatar
redlude97
Old Sep 8, 2008 | 11:13 AM
terrasmak's Avatar
Why is that, the proper answers have already been posted. Do you want someone to say you can run 275's in the rear, someone probably will , and that guy is an idiot.
Old Sep 8, 2008 | 11:52 AM
ryanschram's Avatar
ryanschram
cant close the thread.
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
