Need Tire Size Recommendations - 18x9 and 18x10.5
Apparently i dont understand the 3% rule either. Please help.
Calcuations were done by the miata tire size calculator.
http://www.miata.net/garage/tirecalc.html
I am trying to decide between:
255/40/18 (-0.2% vs stock size)
285/40/18 (-1.1% vs stock size)
265/35/18 (+2.6% vs stock size)
295/35/18 (+2.1% vs stock size)
i am trying to keep the width within 30mm from front the back and minimize the difference from stock in overall height.
Thanks.
Thanks.
If your front wheel was 9.5" instead of 9" I would go with the 265 and 295 setup but the 265 might look odd on a 9" wheel, allthough safe, as long as your offsets are ok for those sizes.
What would look good is 255/40 and 305/35 but your rear offset would have to be spot on.
On the other hand the 255 and 305 might not agree with your Z, unless you have a base model.
Your best bet would be the first choice you mentioned.
Hmmm since you're using spacers, you could actually run a 305 on the rear if you switched to a 10mm spacer. But trust me trying to run a 305 is kind of a hassle.
I would still say go with your first choice. With the 285 rear if you're fenders are not rolled and you're dropped, you 'might' need to cut back to a 15mm spacer or roll the fenders a little but I'm not sure, I think 23 would be ok but could be close to hitting the fender lip.
As far as the 255 and 285 sizes your VDC will be fine.
I would do the 265 295 combo or throw 275/35 fronts with the 295/35 rears. 255/40 and 275/40 combo will also work just fine, you want to change the widths equally front to rear.
