Changing Offsets
Old Oct 7, 2008 | 05:45 AM
SlowHuH's Avatar
SlowHuH
Default Changing Offsets
Does anyone know where I can get the offsets changed to Big Brake friendly offsets? i have iforged Daytonas 19's and the fronts wont fit brembos. Its 2 piece rims. I live in NY
Old Oct 7, 2008 | 07:51 AM
got556's Avatar
got556
Spacers. Now what size I have no idea as I'm not familiar w/ those wheels nor their offsets. IIRC though you need about 3mm clearance between the calipers and the wheel/spokes to be safe. How much are you lacking right now?
Old Oct 7, 2008 | 08:26 AM
resauto's Avatar
resauto
offsets dont make the difference......the wheel face does aka Disk......the only way to clear the breaks now is a spacer
Old Oct 7, 2008 | 08:46 AM
Motormouth's Avatar
Motormouth
you need to get the fitment specs from the BBK manufacturer then measure. then talk to a vendor and spec out rims.
different kits have different size calipers (in width and how far they stick out from the center radially) so you need that.
to 'change' the offsets (lol) you need to either use spacers to move the rims out (if you have room in the fender), or order a new set of rims that are specific to the fitment.
Old Oct 8, 2008 | 07:21 AM
fatboy.yoshi's Avatar
fatboy.yoshi
more info on wheels would be nice...width/disk face (or pad type)/offset.
almost certain u might be able to get away with it using spacers...
but dependent on width and current offsets
Old Oct 8, 2008 | 07:55 AM
OldDirty Z33's Avatar
OldDirty Z33
Pictures plz
Old Oct 8, 2008 | 04:51 PM
OffsetZ33's Avatar
OffsetZ33
Yeah spacers. I have less than 3mm between my caliper and spokes though without any issues.
Old Oct 8, 2008 | 07:02 PM
JETPILOT's Avatar
JETPILOT
You can't change offsets on a 2 piece wheel. Only 3 piece designs can change offsets.
Old Oct 8, 2008 | 07:34 PM
SlowHuH's Avatar
SlowHuH
What spacers should I use and the front rims are 19 x 9 and what about extended lug nuts and if so what brand should i use?
lapham3
Oct 7, 2022 03:15 PM
