OFFICIAL:275/285/295/305/315 Tire Rear shots & Negative Camber shots
Old Jan 7, 2009 | 10:48 AM
  #121
ATX350's Avatar
ATX350
Originally Posted by got556
275/30/19 on 19X10 +15. Soon to be 295/35/19. I bought this wheel/tire setup used and I have a 245/35/19 up front...w/ the different sidewall heights my slip light is freakin sensitive as hell. (Right now I'm on Falken 452's but gonna switch to Nitto Invo's)
Anyways...dropped on Stance GR+ Pro's. (soon as I get new tires for the rear I'm gonna re work the camber and get her sitting nice n flush again.
Hey bro you might want to rehost your pics, they are failing atm as you can see:
http://www.chicagoz.com/forums/pictu...pictureid=1055
http://www.chicagoz.com/forums/pictu...pictureid=1054
Old Jan 7, 2009 | 12:37 PM
  #122
got556's Avatar
got556
wierd...work for me.
I'll fix'em. Thanks for the heads up.
Old Jan 7, 2009 | 01:01 PM
  #123
ATX350's Avatar
ATX350
no problem. Great looking car, I can see why you'd want to get a 295 in the rear.
Old Jan 7, 2009 | 02:12 PM
  #124
Waiz's Avatar
Waiz
Originally Posted by dleariousz
275/40/18zr Sumitomo HTR 2 on Stock 06 Wheels
Not feeling your setup homeslice..
Old Jan 7, 2009 | 08:58 PM
  #125
10b4FouR's Avatar
10b4FouR
[quote=waizzz;6777077]Not feeling your setup homeslice..
honestly a stock look would've been better..but to each his own i guess
Old Jan 7, 2009 | 09:46 PM
  #126
THe Emperor's Avatar
THe Emperor
LOL I didn't know others besides the OP can add tags. LMAO @ those tags.
Old Jan 12, 2009 | 06:21 PM
  #127
Nismospeed4life's Avatar
Nismospeed4life
Originally Posted by JSia
285/35/19
What are you dropped on? Do you have your fenders rolled?
I just got some VOLKS GTF and I have my fenders rolled. And I was wondering if I go with some 285's in the back if it will rub?
Old Jan 12, 2009 | 06:37 PM
  #128
10b4FouR's Avatar
10b4FouR
i have volk GTf on mine and dropped on s-techs..u can actually go as much as 305's..im running 295/30/19's on mine..michellin ps2..wont rub at all just as long as your fenders are rolled
Old Jan 12, 2009 | 06:41 PM
  #129
Nismospeed4life
My fenders are rolled. However, I wanted to run 285/35/19's. Do you feel that the 35 height will make a difference on wether it will rub or not?
Old Jan 12, 2009 | 07:01 PM
  #130
greyson's Avatar
greyson
I run michellin pilot sport cups 305/30/19's rear with rolled fenders - no problem 30+ offsets. 265/30/19 fronts no rolled fenders 30+ offsets no problem. No pictures since this is chicago and the wheels are track tires and car is dormant until spring. no go in any snow!!!!!! argh!!!!
Old Jan 12, 2009 | 07:04 PM
  #131
Nismospeed4life
How low is it dropped? Mine is dropped an inch.
Old Jan 13, 2009 | 04:16 PM
  #132
greyson's Avatar
greyson
At least an inch. Was lower but raised it 1/2" for ground clearance on the new ground effects kit only 2 1/2" off the ground.
Wheels shown are 295/30/19 rear toyo's. michellins are for track only
Old Jan 13, 2009 | 04:29 PM
  #133
JSia's Avatar
JSia
Im dropped on skunk2 springs and yes I had my fenders rolled. I recently got some 295/30/19's
Old Jan 13, 2009 | 05:08 PM
  #134
THe Emperor
Whats the drop on those Skunk2 springs JSia? Nevermind, I found out.
Old Jan 13, 2009 | 05:53 PM
  #135
Nismospeed4life
Thanks!
[QUOTE]
It looks awezome! Thanks!
Old Jan 13, 2009 | 06:25 PM
  #136
matix101vz's Avatar
matix101vz
Originally Posted by kasimmmmm
285/35/19 on 22 offset wheels in the rear... mad rubbage. Need to roll my fenders.
wheel specs????
Old Jan 13, 2009 | 06:35 PM
  #137
Nismospeed4life
+1 ^^ I also would like to know if you have rolled your fenders since, and if you have, are you still rubbing?
Old Jan 13, 2009 | 07:30 PM
  #138
Russ@Z1's Avatar
Russ@Z1
Greddy Type S coilovers, rears all the way down, fenders rolled, and 285/35 tires on 19" TE37's with a +22 offset
Picture taken under hard acceleration
Old Jan 13, 2009 | 08:00 PM
  #139
tired's Avatar
tired
Side view? That looks pretty cool!
Old Jan 14, 2009 | 06:46 AM
  #140
Russ@Z1's Avatar
Russ@Z1
