TOYO R888 QUESTION???
Old Oct 23, 2008 | 07:33 AM
JETPILOT's Avatar
JETPILOT
Actually...... I am now running an 18" rear wheel all around. I have a 275/35/18 in the front and a 305/35/18 in the rear. But the 18" front and the 19" rear was fine I just wanted a 305 tire. I was using a 295/30/19. The 305/30/19 was only approved for a 10.5" rim and I am using a 10" wide rim. The 305/35/18 can be used on a 10" wide rim so I went that route so now I have 18's all around.
Old Oct 23, 2008 | 10:54 AM
idrmofs7's Avatar
idrmofs7
well im figuring if you can run a 305 on a 10'' rim then a 295 on a 10'' rim will be just fine! and once again thank you!
Old Oct 23, 2008 | 12:05 PM
Maxima SE's Avatar
Maxima SE
i think 1010tires.com's tire size calculator is off by 0.5" on tire fitments
Old Oct 23, 2008 | 02:16 PM
JETPILOT's Avatar
JETPILOT
Just go by the manufacturers recomended rim/tire width chart. You'll always be safe.
The 305/35/18 is approved for a 10" rim in the 18" size becasue of the taller sidewall. You should not put a 305/30/19 on a 10" wheel as per the manufacturers specs don't allow it. The height of the sidewall plays a factor.
You're welcome!
Old Oct 30, 2008 | 06:36 PM
Tac-M's Avatar
Tac-M
jet, OMG ! that is one fast z.
Old Oct 30, 2008 | 07:44 PM
JETPILOT's Avatar
JETPILOT
Thanks!
Old May 5, 2009 | 12:25 PM
SIR_pierre's Avatar
SIR_pierre
is the Toyo R888 wider then a regular street tire in the same size? ive heard something about that
Old May 5, 2009 | 01:16 PM
Tac-M's Avatar
Tac-M
refer to the PDF... all tires are slightly different.
Old May 5, 2009 | 01:33 PM
SIR_pierre's Avatar
SIR_pierre
dont find any PDF.......
Old May 5, 2009 | 01:41 PM
Kwame's Avatar
Kwame
Yes, they are. Sure all tires are different but I have yet to see a street tire including the PS2 equal in size to a similarly sized R888.
Old May 5, 2009 | 01:59 PM
SIR_pierre's Avatar
SIR_pierre
ok.. im just worried about them beeing to wide. i have 255/295 today and the scratch sometimes
Old May 5, 2009 | 02:18 PM
scotts300's Avatar
scotts300
bump anyone with R888's?
My 285 R888s are pretty darn wide. I have a pair on 10.5" wheels and they look slightly stretched because of the 30 sidewall. The other pair is on 9" wheels and they look slightly pillowed.
Many people put 275s on 9" wheels, that's sort of the "accepted maximum" on a 9" wheel. Rules of thumb are to add 10mm of tire width for every 1/2" (12mm) of additional wheel width, putting the 295 at the lower acceptable limit on a 10" wheel. I see no problem with it myself.
Old May 5, 2009 | 11:12 PM
SIR_pierre's Avatar
SIR_pierre
but are a 295 R888 tire wider then a 295 vredenstein for an example
Old May 6, 2009 | 04:05 AM
Kwame's Avatar
Kwame
YES
Old May 6, 2009 | 05:28 AM
Jason333's Avatar
Jason333
hi
The Vredestein 295's are quite narrow.
Old May 6, 2009 | 05:59 AM
SIR_pierre's Avatar
SIR_pierre
i thought so to. i had pilot sport 286 before and they looked wider.
problem for me now is that there isnt a R888 255/19 tire.. and i cant fit smaller..and i think if a 265 is wider then normal tires then i cant use it.
what do you guys use? i have 9.5 in the front and 10.5 in the rear i think .
Old May 6, 2009 | 07:14 AM
Ataru074's Avatar
Ataru074
if you are right (about your wheel size) and are 19" you can put 265F and 295R.
check camskill in uk for a really good price (shipped) to sweden.
Old May 6, 2009 | 07:17 AM
  #38
SIR_pierre's Avatar
SIR_pierre
yes the tire on the wheels is no problem at all. im worried about it not fitting inside my fenders
today i have 295 vredenstein in the rear and they scratch when taking corners
Old May 6, 2009 | 08:37 AM
  #39
Tac-M's Avatar
Tac-M
i have 265/30/19 on a 9.5 front and 295/30/19 on 10.5 rear.
front fits good, rear will need to have rolled fenders and more negative camber.
i plan on -3 camber on all 4.
Old May 6, 2009 | 09:13 AM
  #40
scotts300's Avatar
scotts300
Depends on the offset, but if your 295 Vredensteins don't fit properly in the rear, it sounds like the larger 295 R888 won't make the issue go away.
Again - depends on offset. YOU may need the rear fenders rolled with more neg camber, but not all set-ups would - especially for a 295-sized tire.
