Owners with Crazy/Aggressive Offsets
Old Oct 25, 2008 | 07:31 PM
gennosuke1's Avatar
gennosuke1
Default Owners with Crazy/Aggressive Offsets
owners with that crazy/aggressive "flush" look your help is needed. I just recently put new wheels and tires on my car.
front tire are 245/35/19 and rear are 275/35/19
rims are 19 inch 8.5 wide in front and 9.5 wide in rear. Offsets are +25 front and +22 rear
I was thinking about getting the tanabe nf 210 sprngs and was wondering when i take it in the shop to get it alligned, if i get ask for negative camber will that help with bringing out the tire?
If not and i end up getting spacers, i will obviously rub and would have to get fenders rolled. I have SEARCHED and found the aggressive thread but that only showed pics so your help would really be appreciated!!
Old Oct 25, 2008 | 07:35 PM
gennosuke1's Avatar
gennosuke1
this is only pic i have with link right now but look at the red one, i am loking for a little more out just a little (hope owner doesnt mind)
https://my350z.com/forum/attachments...redline-n3.jpg
Old Oct 25, 2008 | 09:30 PM
singh's Avatar
singh
_______________
Get the springs installed and post some pictures. Then someone can offer some legit assistance as to exactly what mm spacers you are going to need.
Sacrificing a proper alignment for a flush look is so stupid.
Old Oct 26, 2008 | 12:28 AM
gennosuke1's Avatar
gennosuke1
hmm thanks for the advice
someone told me though that when they realign the car after they put springs on, having little negative camber was ok or at least the amount they suggested
Old Oct 26, 2008 | 12:47 AM
johzp's Avatar
johzp
heres mine.
I think the nf210s will lower the car >1" therefore you will need a rear camber kit to get the car back within factory specs...as the oem camber arms are only adjustable within some tenths of a degree.
The more you drop your car the more camber you will get and the more sunken in the wheel will look.
Old Oct 26, 2008 | 04:02 AM
Kwame's Avatar
Kwame
19 x 8.5 +25 and 19 x 9.5 + 22 are not considered aggressive for a 350z.
When you do get the car lowered naturally there will be a slight increase in the amount of negative camber that your car will have. Why you might ask for more I am not so sure but it will make your wheels look really tucked in according to the specs that you have mentioned earlier.
If your end goal is too achieve the "flush" look then you will have to buy spacers.
Old Oct 26, 2008 | 11:04 AM
gennosuke1's Avatar
gennosuke1
oh ok hmm hey john how can i get similar look as you, do you have coilovers or springs and how much is your car dropped?
since i have seen it in person i like the drop
also i know those arent aggressive offsets just mentioning it to see how to get that look and can someone tell me what is the disadvantage of having wheel spacers?
thanks
Old Oct 26, 2008 | 11:24 AM
ohSIXz's Avatar
ohSIXz
if yer gonna keep those wheels, get some 10mm spacers if u want aggressive, and if u want stretched, yer gonna have to run like... 205 front and 225 rear.
it seems like for good aggressive offset/stretched tire on a Z/G the nicest seems to be 19x10 19x11 +0 with like.. 245 front 275 rear. i think ima do something like that once i sell my GTS.
Old Oct 26, 2008 | 11:44 AM
amg55driver's Avatar
amg55driver
if you put atleast 25mm spacers all around, than Maybe, its aggressive.......
Old Oct 26, 2008 | 02:36 PM
gennosuke1's Avatar
gennosuke1
so im guessing everyone with these "aggressive" offsets had their fenders rolled right?
Old Oct 26, 2008 | 02:45 PM
deviljon's Avatar
deviljon
10mm spacers aren't going to do jack. you're setup is still going to look weak because your wheels aren't wide and the offsets are bad.
if you want an aggressive look, you might want to consider a smaller tire size and wider wheel. a few degrees camber isn't too bad. i dont think you'll necessarily need coilovers, but most springs wont be able to drop your car a whole lot.
and yes, roll those fenders, but dont cut them. fold them if you have to, and even pull it out a bit if you think you'll need it.
Old Oct 26, 2008 | 03:17 PM
gennosuke1's Avatar
gennosuke1
i see thanks for advice
my tires are 245/35/19 front and rear 275/35/19 rear, they are pretty big i dont think i could lower more than 1.5. Right now if i lower it about 1.2 and get spacers i think it will rub
i dont think my offsets are tht weak are they? whats the disadvantage of spacers and wont 25mm work?
Old Oct 26, 2008 | 04:29 PM
deviljon's Avatar
deviljon
the offsets are okay, but because of the width of the wheels, the look is still going to be conservative. with any negative camber your wheels WILL look tucked.
Old Oct 26, 2008 | 06:27 PM
singh's Avatar
singh
_______________
Wheel should fit car. Not car should fit wheel.
Hint: Buy a wheel that has the "aggressive" offsets and then your car will be legit.
Old Oct 26, 2008 | 11:02 PM
gennosuke1's Avatar
gennosuke1
**** man its gay i jsut bought new wheels i cant afford crazy works or volks that are like 3 grand
i think they should start making better wheels out there and not like works are only ones that can come super flush or volks
gay
Old Oct 26, 2008 | 11:52 PM
Kwame's Avatar
Kwame
gay
Its not the wheel manufacturers' fault. In all honesty you picked the wrong wheel for the look that you are trying to achieve. I don't know what your budget was at the time of your wheel purchase but I am sure with a little more research pre-purchase you might have been able to find something that fit your goals (price wise and visually).
Old Oct 27, 2008 | 11:46 PM
gennosuke1's Avatar
gennosuke1
i think i ended up spending around $2200 roughly i think w/o locks
the tires are included in price
i searched around and i was going to buy the xxr 006 but i heard they are shitty wheels from a lot of people so i found 5zigen, thats basically all i found and thats what i got recommeneded for mesh wheel
the front lip comes around 2 1/4 and rear is 3 1/4
Old Oct 28, 2008 | 07:40 AM
str8dum1's Avatar
str8dum1
all you need is some 25 mm spacer and you;ll be fine.
Old Oct 28, 2008 | 04:05 PM
gennosuke1's Avatar
gennosuke1
thanks
Old Oct 28, 2008 | 07:23 PM
OldDirty Z33's Avatar
OldDirty Z33
My thread that I started a bit ago?/
https://my350z.com/forum/wheels-tire...offsets-2.html
