rims size question
Old Oct 31, 2008 | 10:24 AM
matix101vz's Avatar
matix101vz
Default rims size question
i have stock 18x8 rims on right now and i have 225/45/18 tires in the front and 245/45/18 tires in the back ... will those tires fit on rims 18x9. please respond. i am in a rush and didnt have much time to search for a size calculator
Old Oct 31, 2008 | 10:41 AM
I would not put a 225 mm tire on a 9.0 inch wheel.
Old Oct 31, 2008 | 10:52 AM
calin's Avatar
calin
If you're in a rush, then searching for a size calculator might be a better idea than posting here
Old Oct 31, 2008 | 11:40 AM
matix101vz's Avatar
matix101vz
i saw on the aggressive stretch thread that some1 had a 225mm tire on a 9.5 in wheel.
is there a special way to put stretched tires on?
Old Oct 31, 2008 | 06:45 PM
terrasmak's Avatar
Fits fine , i did it for a while with my first set of wheels.
Old Oct 31, 2008 | 07:27 PM
Spike100's Avatar
Spike100
225/45-18" on 18x9" rims are stretched a little. You can do that, but be careful.
Be sure that you have a good seal at the bead, and check your psi frequently.
Buy wider tires as soon as you can.
--Spike
Old Nov 2, 2008 | 06:20 PM
matix101vz's Avatar
matix101vz
its ok i bought 255s for the rear and going to use the 245s on the front
issyz
Jul 2, 2017 03:04 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
