Axis Se7en Mod 20x9 and 20x10 fitment on 350z
Old Dec 1, 2008 | 09:53 AM
MyIS300's Avatar
MyIS300
Default Axis Se7en Mod 20x9 and 20x10 fitment on 350z
Hi,
Grab me a set of Axis 7 mods
20x10 et38
20x9 et37
How will these look? Will it rub? Do I need spacers? If so, which ones?
Old Dec 1, 2008 | 10:16 AM
kaminariZ's Avatar
kaminariZ
i have these with 15mm spacers all around. they rub a little in the back, but not the front. i got 285/30/20 on the rear tires. they are stunning on my superblack Z. i get looks everyday!
Old Dec 1, 2008 | 10:18 AM
MyIS300's Avatar
MyIS300
what do you think about 20mm spacers all around?
Old Dec 1, 2008 | 12:23 PM
MyIS300's Avatar
MyIS300
when we say 20mm spacers is it 10mm on each wheel? or is it 20mm on each wheel?
I'm using this calculator here:
http://www.1010tires.com/WheelOffsetCalculator.asp
I have stock 18" touring
which is:
Front
Offset: +30mm
Weight: 24.4
Tire: 225/45/18
Rear
Offset: +33mm
Weight: 25.8
Tire: 245/45/18
the axis 7 mod's are
20x9 +37
20x10 +38
the calculator says 20mm less, what does that mean?
Old Dec 1, 2008 | 04:37 PM
EIGHT08FLIP's Avatar
EIGHT08FLIP
https://my350z.com/forum/north-west/...-his-ride.html
Here is a link to a pic of my car with same Axis wheels you are looking at. Im running 265/35/20 up front and 285/35/20 in the rear. There are no spacers on during the pic, but I will be putting 20mm spacers on all four corners. I want the wheels more flush with the fenders.
Also I'm lowered on Tanabe Gf210 springs with a mild rear fender roll.
Old Dec 1, 2008 | 06:35 PM
Triple8Sol's Avatar
Triple8Sol
Originally Posted by EIGHT08FLIP
Im running 265/35/20 up front and 285/65/20 in the rear.
You sure about that?
Old Dec 1, 2008 | 08:12 PM
terrasmak's Avatar
Great wheel for an SUV, not a sports car. Go for something that in the 18 to 19 inch range.
Old Dec 1, 2008 | 09:04 PM
kelsey_kaye's Avatar
kelsey_kaye
not everyone is all about performance.
Old Dec 1, 2008 | 11:22 PM
MyIS300's Avatar
MyIS300
20mm spacers or 15mm spacers? any specific brand? cost?
Old Dec 2, 2008 | 07:23 AM
EIGHT08FLIP
oh snap! I just ran out an checked and yes there 65.
Old Dec 5, 2008 | 03:37 PM
kaminariZ's Avatar
kaminariZ
you want 15mm spacers on each corner. do not go more than 15mm spacers in the rear unless you plan on running camber and lowering your ride, as well as rolling your fenders. in the front, 20mm is good. they are actually quite light wheels if for 20's. i put 20" in the rear and 19" in the front. i like it a lot
Old Dec 5, 2008 | 03:40 PM
kaminariZ's Avatar
kaminariZ
here is my car. 20x10 +22 rear, 19x8 +24 front.
Attached Thumbnails Axis Se7en Mod 20x9 and 20x10 fitment on 350z-n32818883_34394370_9913.jpg
Old Dec 5, 2008 | 05:44 PM
Been a member for 4 years, and do not use a offset calculator? Geeze thats lazy.
Old Dec 12, 2008 | 01:13 PM
MyIS300's Avatar
MyIS300
Front
Offset: et37
Tire: 255/35/20
Rear
Offset: +38et
Tire: 255/35/20
What does everyone think of this setup?
What PSI should I be at with this setup?
Should I get 20mm spacers all around?
davidm350
Oct 31, 2015 02:28 PM
