unique wheel fitment issue/spacer question
Old Dec 13, 2008 | 08:22 AM
Deliverance's Avatar
Deliverance
Default unique wheel fitment issue/spacer question
Buddy of mine is letting me run his Enkei Evo 8 wheels on my car. Something different i haven't seen done yet and they are much lighter than stock.
So i got some spacers to make the wheels flush but here comes the problems. 5mm spacer i got from a local auto store doesn't fit cause of what lookes like a bleeder valve on the Hub ??? the evo wheel almost clears it but im def gonna need a spacer to drive safely so i'm curious where i can get a spacer that will fit according to this valve .
Now to the problem n the back. Spacers didnt fit there either cause of the hubcentric ring. the wheels fit great and look awesome but are ways from flush and i'm gonna need new lugs. So if anyone can point me int he direction of spacers and sizing that would work and what kind of lugs i need to look for ?
thanks for the help
Old Dec 13, 2008 | 06:56 PM
anotheraznguy's Avatar
anotheraznguy
#1 pull of that dang thing in the front..
#2 get some project kics spacers..
done and done..
Old Dec 13, 2008 | 09:05 PM
Deliverance
done and done..
i would pull it off but it looks rather important! and i would take pictures but i don't feel like pulling the wheels off again. Someone here knows what i am talking about.
Old Dec 13, 2008 | 11:12 PM
kelsey_kaye's Avatar
kelsey_kaye
if it's just a small bolt with a shim around it take that sucker off.
Old Dec 14, 2008 | 06:37 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Yes, this IS a very special question.
bleeder valve? No. 10mm bolt and shim? Yes. Remove it, install your wheels.
Also be sure to check out the top 100 questions thread.
Old Dec 14, 2008 | 07:04 AM
Sunset350ZR's Avatar
Sunset350ZR
Do what they said. Regardless of what happens do ^ or some questions like these will require a flame retardent suit. Get some pics of what it looks like when you are done. How wide are these rims anyway?
Old Dec 14, 2008 | 07:15 AM
z-u-later's Avatar
z-u-later
Do a SEARCH and you'll find out what this bolt is . . .
Workshop12
Mar 23, 2020 01:45 PM
issyz
Jul 2, 2017 03:04 PM
PLAYDIRTY
Oct 12, 2015 07:45 AM
