Tire experts! WTF am I doing wrong here?
Old Aug 25, 2003 | 09:47 AM
droideka's Avatar
droideka
Unhappy Tire experts! WTF am I doing wrong here?
I'm on my fourth set of tires in one year and my rears have already hit the wear bars in only ~5K miles! The center of the tire wears out long before the edges. I don't do standing start burnouts and I've had three sets wear like this BEFORE the suspension. WTF is going on? This is getting ****ing expensive.
Old Aug 25, 2003 | 09:49 AM
Topics II's Avatar
Topics II
what are your tire pressures?
Old Aug 25, 2003 | 10:20 AM
droideka's Avatar
droideka
35 cold.
Old Aug 25, 2003 | 10:27 AM
D'oh's Avatar
D'oh
If the centers are wearing out before the edges (and I mean significantly before) then you may want to lower your pressures a bit. Maybe 3 psi or so. This would help distribute the weight better.
Have you checked the alignment of the rear tires? Maybe the toe-in?
My rears have lasted 21000 miles (just replaced them) and they wore pretty evenly, with a slight bias towards the inside edge.
I drive about 50% windy road and 50% highway, and I drive the twisies pretty hard. I don't know if that has anything to do with it.
Good luck!
-D'oh!
Old Aug 25, 2003 | 10:43 AM
johnlotusboy's Avatar
johnlotusboy
What is your wheel and tire widths and could you get a load range index number off the side wall of the tire. If not just post brand, size and rim with and I'll look up some information for you.
Old Aug 25, 2003 | 11:22 AM
droideka's Avatar
droideka
Check my sig for the info.
Old Aug 25, 2003 | 11:26 AM
lowrider's Avatar
lowrider
The wheel width on the Rays is 8" front and 8.5" rear. They should work fine. When I replace, I'm planning on running the same sizes on my 8" G35C wheels.
Lou
Old Aug 25, 2003 | 11:41 AM
sparky3Z's Avatar
sparky3Z
This is a ridiculous question, but just in case—are you sure your tire gauge is accurate?
Old Aug 25, 2003 | 12:00 PM
droideka's Avatar
droideka
Not ridiculous. It's one pound off negative. I also check with a hand-held gauge every few days. Yes, I'm a psycho.
Old Aug 25, 2003 | 03:10 PM
johnlotusboy
Sorry I had the sig lines turned off to maybe help this slow A$$ sight load to my cable modem faster.
Your oem tire was a load range 96 which supports 1510lbs @35psi
You new tire is a load range 99 and 32psi it supports 1543lbs and you are at the minimum rim widthfor the tire so i would suggest 30-32psi as a starting point for inflation .
I would try 33psi in your fronts also, or maybe 32psi.
Old Aug 25, 2003 | 03:16 PM
droideka's Avatar
droideka
I thought you were going to say that. Guess what? I put these tires on in late June and started them at 30 psi cold because I thought I had a problem with the tires getting too hot and riding on the center ribs which caused the wear.
They're at the wear bars 5K later. How's that for sh:tty lifespan?
Old Aug 25, 2003 | 03:27 PM
johnlotusboy
Really soft tires in a hot climate wear much fast than the area where I live, but center wear out or other uneven wear in usually correctable with some form of adjustment.
Old Aug 25, 2003 | 04:47 PM
MY350Z.COM's Avatar
Originally posted by droideka
Yes, I'm a psycho.
I can vouch for that.
Old Aug 25, 2003 | 08:29 PM
raceboy's Avatar
raceboy
Lower your tire pressure Droid. 31-32psi cold. Keep in mind that those are tire pressures that Nissan puts in place so you will have adequate pressure no matter what climate you live in, so if you live in Alaska and it never gets about 40 degrees, the car will still have 35psi in the tires minimum. In Texas, even if you start out with 30lbs in the tires, you will be at 33-35lbs in just a short bit of highway driving. Just to soften the ride, Nissan recommends 32lbs in the heavier roadsters, so I am sure it's safe (besides, how many roadsters are they gonna sell in Alaska?) I run 32lbs cold front and 31lbs cold rear now.
Old Aug 25, 2003 | 10:04 PM
droideka's Avatar
droideka
See three posts up. I already did that with this set. The rears went from 30 to 35 during my hour long commute. That's why I'm so alarmed. I'm already looking for a daily driver now.
Old Aug 26, 2003 | 08:20 AM
ares's Avatar
ares
Veteran
you dont autocross, or otherwise race with em? I know you said no burn outs, but even a peel here and there, and an autocross will tear em up.
a day on the track can easily cut the tires life in half. specially in the heat on a soft compound.
Old Aug 26, 2003 | 10:22 AM
jelledge's Avatar
jelledge
Default Tire Wear
I don't think the tire pressure is your problem. I have the same S0'3 on my car for about 7k miles now and they look brand new (and that includes one auto cross). The wear on them is very even and minimal. I am running 35psi cold. I live in Boise, Idaho where it is 95-100F all summer. When driving around the tires get up to about 38-39psi.
Have you taken your car to an independent shop to check all alignment settings and verify suspension is working properly?
The S0'3 have a treadwear of 240 and should not wear out this fast with normal driving. Wearing the center of the tires is generally an indication of too much pressure, but sounds very odd to be wearing so fast.
Suggestions:
1. Take car to Bridgestone tire dealer and say WTF is going on with these tires.
2. Try a couple other tire pressure gauges to be sure of your tire pressures.
3. Verify all wheel alignment settings are in spec.
4. Verify rear shocks are working properly.
The only other thing I can think of is you have the track wheel and I have the 18" touring wheels. The track wheels are a little wider, but I can't imagine this would be the problem.
Good luck.
Obadabot
Jun 18, 2023 11:31 PM
Rev_Night
Nov 7, 2020 06:00 PM
