Suggestions for spacers/tires *pics*
Old Dec 25, 2008 | 09:59 PM
elvis's Avatar
elvis
Default Suggestions for spacers/tires *pics*
Hey guys,
I just put on my "new" wheels to see how the fitment would be on the car with the spacers i have. The wheel specs are:
19x10.5 +35 R
19x8.5 +22 F
I have a set of 15mm spacers which are put on the pics I was wonderind if I could go even farther out maybe 20-25mm spacers and switch the 15s to the front wheels.
Give me some suggestions and some tire sizes that would work with your suggesting setup.
Here are the pics:
(Keep in mind the wheels are just hanging so the way they sit will change a bit)
Old Dec 25, 2008 | 10:01 PM
elvis's Avatar
elvis
I want to try and get the wheels to go a little past the fenders and have the tires sitting flush. I don't mind going a bit stretched but nothing overboard. I am also planning on buying coilovers before summer hits.
Old Dec 26, 2008 | 01:26 PM
FliPPER_Z's Avatar
FliPPER_Z
rims look really nice,dont know much about specs on wheels...but ill take your OEM wheels if you decide on selling them
Old Dec 26, 2008 | 02:46 PM
Chad68's Avatar
Chad68
My wheels are the same spec as yours and my 305's required tweaking the lip.
If you are going to stretch 275's you might be able to use a 10-15mm spacer. No way in hell you will be able to run a 25mm spacer unless you run lots of camber, which would look lame and your tires will wear like kaka.
My outer lip is about 3/4" from being flush or a lttle less and that's with excessive camber.
Best bet is decide what size tires you want to run, install them and put the car on the ground and figure from there.
Old Dec 26, 2008 | 03:08 PM
elvis's Avatar
elvis
Right now I have a 15mm spacer on the rear in the pics.
What tire size are you running for your fronts if your rears are 305?
Old Dec 26, 2008 | 03:55 PM
Chad68's Avatar
Chad68
245/35/19 on 8.5" wheels.
Old Dec 26, 2008 | 05:49 PM
elvis's Avatar
elvis
Doesn't that throw of your VDC?
Old Dec 26, 2008 | 06:24 PM
Chad68's Avatar
Chad68
I have a base model, so no. Even if it wasn't a base it would be fine since rears are about 1/2"+ larger dia. than the front.
What size tires you going to run on the back end? also are you lowered or plan to lower? That makes a big diff in what works as well.
Old Dec 26, 2008 | 08:42 PM
elvis's Avatar
elvis
Yah I plan to lower for sure, on coilovers
I would like to run something like a 295 in the rear that would be ideal but its hard to make that work with a 8.5" wide front rim
EDIT: You'r right a 305/30 would run with a 245/35 no problems How do they fit on the car? Are you running spacers at all or just +35 offset?
Old Dec 26, 2008 | 11:05 PM
Chad68's Avatar
Chad68
No spacers. There are some pics in my album.
Old Dec 26, 2008 | 11:24 PM
elvis's Avatar
elvis
looks good man
I think im gona get 20mm spacers for my rears and swap the 15mm to the front and go with a 245/275 35 series setup and if i get bored of it or the spacers dont do it for me I will do up your setup
Pleask
Dec 21, 2021 03:17 PM
ablaine
Nov 29, 2016 10:13 AM
